Should that matter? Not that i didn't try but it still shouldn't matter........
There shouldn't be a vcore issue if its not a chip limit.
I already established that the issue surfaced after a few days 1.4+ was fine now its a problem to set over 1.325.
came with a really early bios, I ended up flashing both the backup and main bios due to being plagued by flashbacks and rebbot loops kept triggering flashback.
Problem manifested itself however after that and like i said earlier it happened after messing with ez tune in windows. I was running prime and dropping a notch every hour, when i found the crash point this problem showed up.
