Not sure I did this right?
i7 2600K Batch L038A660
Mobo ASUS P8P67 Deluxe. Bios 1053.
Cooling Air. Thermalright Venomous X-RT.
This may actually run on lower Vcore as I threw 1.4100v at it in bios and ran the test.
Could someone do a HT-off run with a lot of memory on IBT(or linx)? How many gflops are you maxing on, let's say, 5GHz ?
Can one of the over-5GHz folks kindly post a Cinebench 10 and 11 screen, just for kicks? My i7-930@4.2 gets 24600 & 7.16, respectively. TIA.
Dropped the Vcore 3 notches from above post.
i7 2600K Batch L038A660.
Bios set at 1.395v.
Min during test 1.398v.
Max during test 1.408v.
http://i54.tinypic.com/16aaefd.png
Only 1024mb ram, but in my experience the gflops didn't change between RAM levels
@crossg:
Hey could you post your UEFI Bios settings?
Got my SB already just waiting for my P8P67 and Thermalright 1156 mounting kit to arrive...
http://i56.tinypic.com/b7xgso.png
Bit hot but you get the idea :D
Good to see all these 5GHz+ 24/7 stable popping up. :)
I have a impression MBs are playing smaller role in this round, because you can't push the BCLK, and won't need to push the MB with a unlocked CPU, either. Some BIOSes will need some time to mature tho.
Anybody got a good experience with 2006k on mini/micro-ATX? Or, what mini/micro-ATX would you guys recommend?
2600K batch: L042B074
MSI P67A-GD65 bios 1.6
2x2GB Team Xtreem LV
4800Mhz @ 1.256v bios - 1.24v idle - 1.288v load
Moved v v
crossg, I just made an Asus p8p67 oc thread :-) post away.
SBB, awesome oc and batch. But volt and temp seem high :-/ Will it do lower voltage?
No mate,that is the actual voltage set in bios and reported right,asrock mobo doesnt have the problem like gigabyte :rolleyes:
So,5 ghz 1.33 anyone :D ?
http://img72.imageshack.us/img72/3714/5ghz.jpg
Uploaded with ImageShack.us
That's a golden chip. :up: And even better this baby has landed in Europe. :)
So C-batch-baby is the way to go? Everything is strange in this round, anyways, LOL
Good I've waited in this round. Now I've to track down this batch# and I may find it, hopefully in Norway.
EDIT: Talking to Alex on PM, so no need for the rest :).
EDIT2: Who else got a C-batch? Anybody got a list of documented results with C-batch# on this (or other) forum?
That is certainly a nice chip, yet another keeper.:up:
Got the same batch number as Alex-Ro, same 1.31V set in BIOS and 1.324-1.327V reported in AXTU, mobo ASRock Extreme4, stable fully at 5019.61MHz.
P.S. I have seen lots of guys posting here results with LinX with their 2600K running at 5ghz and having around 60-61Gflops. Doesn't this mean that their CPU is throttling?
L042A969
http://www.vmodtech.com/main/wp-cont...o/dsc_0371.jpg
http://www.vmodtech.com/main/wp-cont...o/dsc_0101.jpg
I think LinX isn't absolute stabilities test for Sandy Bridge.
I passed it at lower VCore but it not pass CPU Test of 3DMark 03 , 3DMark 05 & 10K Prime95.
CPU ..Intel Core i7 2600K
Motherboard ..ASUS P8P67 PRO
Memory ..G.Skill F3-17600 CL7D-4GBPIS 2GB*2 Dual Channel
Graphic Card ..GTX 580 @ 985/1,970/4,640MHz
Harddisk ..WD1002FAEX 1TB SATA3
CPU Cooler ..Water Cooling @ Ambient 25C
Power Supply ..Antec TPQ-1200 OC Version 1200W
Operation System ..Windows 7 Enterprise 32-bit
http://www.vmodtech.com/main/wp-cont...linx5217-2.png
http://www.vmodtech.com/main/wp-cont...7-pro/occt.png
http://www.vmodtech.com/main/wp-cont...23h27-cpu1.png
http://www.vmodtech.com/main/wp-cont...23h27-cpu2.png
http://www.vmodtech.com/main/wp-cont...23h27-cpu3.png
http://www.vmodtech.com/main/wp-cont...23h27-cpu4.png
http://www.vmodtech.com/main/wp-cont...3h27-vcore.png
Prime95 Blend Mode 1024K, 8K, 10K, 856K & 768K 1Hour 22Minutes
http://www.vmodtech.com/main/wp-cont...rime5217-1.png
http://www.vmodtech.com/main/wp-cont.../5217hpi_1.png
http://www.vmodtech.com/main/wp-cont...p67-pro/v1.png
http://www.vmodtech.com/main/wp-cont...o/pcmark05.png
http://www.vmodtech.com/main/wp-cont...p67-pro/e1.jpg
http://www.vmodtech.com/main/wp-cont...p67-pro/03.png
http://www.vmodtech.com/main/wp-cont...p67-pro/05.png
http://www.vmodtech.com/main/wp-cont...7-pro/3d06.png
http://www.vmodtech.com/main/wp-cont...7-pro/07np.jpg
http://www.vmodtech.com/main/wp-cont...-pro/3d07p.jpg
http://www.vmodtech.com/main/wp-cont...p67-pro/11.png
Are you testing all ram Venom crusher ? 1.8Gb from 4 seems a bit low... It also depends a lot on the LinX version used... but you are right there's no 100% bulletproof stability test
