I will wait for the Biostar Bios with the OC unlock feature.
Looks like that the D2 runs better than the D1...
I wanna use all ram slot to get 16GB, and oc'ing to 5 GHz. What kind the cooler do i need and the ram to fulfill my pan on P67 boards?
The 1055 board ram slots seems very narrow to CPU cooler. Looks like SB just need low profile cooler since Anand said intel stock will do 4.5 GHz oc'ing.
The 3rd party cooler like MUX-120 or Tuniq Tower 120 Extreme has 47 height clearance, 2-6mm dimm obstruction (others less i believe), there's no way i can put 4 sticks 52mm tall dominator ram there.
Can i put Team Extreem LV 2000 there? or what kind memory do you suggest?
another OC Guide from MSI:
http://www.msi.com/index.php?func=do...1&prod_no=2225
Ok, Biostar did their job also with a new bios.
It will be soon available, i just got a message :-)
This is not correct, sir.
http://www.overclockers.at/attachmen...3209&thumb=650
http://www.overclockers.at/attachmen...3210&thumb=650
new bios for M4E
http://www.mediafire.com/?0t55ne2t53x4o3k
Small glitch first few key strokes no response in bios menu – will fix soon
http://www.pt1t.net/P67/UD7/cpuz_1562.zip
CPUZ beta with correct reading of Vcore on gigabyte P67/H67 Boards
Pt1t, do you have access to the Biostar ftp. Got the Link from them but no login data
Thx!
Yes.
