Yep all 3 PCIE slots are spread pretty well. Really starting to erk me though trying to figure out why the VRMs are getting so hot.
Seems Thermalright are on the case. shame it's so huge!
http://www.techpowerup.com/img/10-09-15/105b.jpg
Thermalright Readies Shaman 140 mm VGA Cooler
If would be great if you could mount the fan on the underside of the heatsink, blow air away from the card it would only be a 3 slot cooler then. Which would make SLI possible on some boards.
Thermalright coolers is so good , but too big , taking up 3 slots its quite possible .
Forget about Crossfire / SLI user .
Not as it currently is, If you replaced the 140mm fan with a slimline 120mm then maybe but you'd lose the CFM and as a result the great temps.
Thermalright just need to make a slimmer version. Many motherboards have Crossfire/Xfire layouts allowing for 3 slot coolers. So I'd imagine they'd sell enough.
Come on Thermalright, slim it down.
Take it theres still no joy on the aftermarket cooler front for the palit sonic 1gb cards ?
seem so, but I'm waiting water block from EK
"New full cover block for non reference Geforce 460GTX cards - 14/10/2010
We are developing new full cover block for Palit and Gainward GeForce 460GTX series.
Blocks will be available on 5th of November."
The ZEROtherm COOLMAXX 3000 might fit this card?
I hope they will do that
btw the news from their site
http://www.ekwaterblocks.com/index.p...t01returnid=17
ok ... one question
on a refrence pcb which all coolerz can b mounted? ... or we shud wait 4 new co
ive a sparkle coolerz
Is Thermalright going to release the bracket for this Video card?
October supposed to be the ETA
Hey peeps, I have 2 palit sonic platinum 460s and I was wondering if there is some other kind of fan I can install on the original heatsink they have by removing the whole factory plastic cover+fan. Any suggestions? What fans have the same pins as those of graphics cards?
I used something like this to the card direct.
http://www.newegg.com/Product/Produc...82E16835186034
but later i just got a faster 4pin molex fan with controller and strapped it on.
Hi all, just to say that i bought the mk-13, it works amazing on my gigabyte gtx 460 768, but i had to use the stock cooler retention system to tighten the screws but only 2 of them were possible.I overclocked it to 870 core and 2000 mem and my temperatures in furmark are amazing and just with one 120mm 1000rpm NB xl1. :shocked
max temperature was 74ºC after 5min.
Gigabyte GTX-460 768 MB (GV-N460DS-768I-B)
http://www.bjorn3d.com/read.php?cID=1900
I only hear the PSU! lol
http://img705.imageshack.us/img705/6339/img1185j.th.jpg
http://img846.imageshack.us/img846/3316/img1188b.th.jpg
http://img651.imageshack.us/img651/5803/img1189m.th.jpg
edit: http://img198.imageshack.us/img198/6858/img1194g.jpg
and the solution is:
http://img816.imageshack.us/img816/3...3153730223.jpg
:shocked:
I think the http://www.zerotherm.net/eng/product/CM4000.asp]ZEROtherm COOLMAXX 4000 will fit. There is a couple of reviews at the bottom of the pagen in Korean.
To bad I cant seem to get it here in Sweden :down:
