you should be impressed by both because both overclock really well.
http://img819.imageshack.us/img819/6792/460soc.jpg
GTX460/1024MB @900MHZ GPU @4452mhz Ram
Nice ! That's between HD 5850 and HD 5870 but the score is with PhysX activated.
Seems the 1 Gb version will be on par with GTX 465, except it will have much better thermals and will need less power :)
Ok so we have the GF100 and GF104. Next up to bat are the GF106 and GF108.
Since from what i have seen the gtx 460 and 465 would overclock somewhat the same and the gtx 460 has less cuda cores. So why would the 460 be more effective clock per clock than the 465?
If we are talking stock gtx 460 against stock gtx 465. Yeah then they are probably going neck to neck.
I got 800 core / 1600 shaders and 3500 memory on a 465 with ~ 75 full load (weather is over 30 C here!) so would like to see how the 460 performs clock to clock. Doesn't anyone compare architecture efficiency anymore or just it out of the box and call it a day? The 460 looks really good and if the prices can be under 199, then 2 or 3 in sli would be a killer combo. But I did get the 465 for only 210 so might need to pickup a 2nd one before it all goes away. :D
The 460 has 56 TMUs, the 465 has 44.
And the stock 460 has more shader power than the stock 465.
336*1350 vs. 352*1215
In fact, the 1GB 460 should be faster across the board compared to the 465. It has more shader power, more memory bandwidth, more TMUs, and the same number of ROPs.
The 768mb version should trade blows. It has lower memory bandwidth, but more TMUs and more shader power.
nvidia is killing the GTX480, you can get two GTX460s (factory OCed to 800/1000mhz) 1Gb in SLI for the same $$$
first review: http://www.expreview.com/11276-1.html
http://www.expreview.com/img/review/GTX460/3DM.png
http://www.expreview.com/img/review/GTX460/l4d.png
http://www.expreview.com/img/review/GTX460/JC2.png
http://www.expreview.com/img/review/GTX460/crysis.png
http://www.expreview.com/img/review/GTX460/wic.png
http://www.expreview.com/img/review/GTX460/dirt2.png
http://www.expreview.com/img/review/GTX460/bfbc.png
http://www.expreview.com/img/review/GTX460/UH.png
http://www.expreview.com/img/review/GTX460/sg.png
http://www.expreview.com/img/review/GTX460/powerc.png
nice card...
Quite respectable. Assuming availability and pricing stay in check, it should be a strong seller.
MSI N460GTX CYCLONE 768D5 OC Edition
http://www.coolaler.com.tw/coolalerc..._N460GTX/3.JPG
728/1800
http://www.coolaler.com.tw/coolalerc..._N460GTX/1.gif
3dmark vantage
http://www.coolaler.com.tw/coolalerc..._N460GTX/4.gif
800/2000
http://www.coolaler.com.tw/coolalerc..._N460GTX/2.gif
http://www.coolaler.com.tw/coolalerc..._N460GTX/5.gif
830/2060
http://www.coolaler.com.tw/coolalerc..._N460GTX/7.gif
830/2060@3DMARK Vantage
http://www.coolaler.com.tw/coolalerc..._N460GTX/6.gif
840/2100@3DMARK Vantage
http://www.coolaler.com.tw/coolalerc..._N460GTX/8.gif
www.coolaler.com
