I've confirmed that my issue with failed boot no overclock and maybe VGA driver crash only occurs when I use all 4 memory sticks in my pc. I've ruled out a dodgy stick or slot. The memory is rated at 1.5v and is running at this.
Any suggestions?
Any suggestions?
It's good to know. The two Samsung SP2004C are in RAID-0.
Yesterday was the worst.
First boot: RAID offline, the two HD642JJ was ok.
Second Boot: RAID offline, no other HDD detected.
Third boot: RAID SMART error, the two HD642JJ was ok.
At this point I've set back the controller to IDE mode, and checked the SMART status on all four drives. Everything was ok (as I expected).
Fourth boot: RAID ok, one HD642JJ was missing.
Fifth boot: Success!
Thanks for the M4A89GTD-Pro/USB3 beta bios saved the day...
:YIPPIE:
I was stuck with 1456 which destroyed my 1090T @ 4ghz OC not even stock was stable....
With 1503 its all good again same settings as 1301 :up:
really hopping a downgrading method will popup soon , was stuck with 1456 for weeks and it was hell and unstable... :down:
M4A79_deluxe is giving me a wicked headache atm.....you have no clue how many workarounds i am using to stay competitive in a comp atm :ROTF:
On top of it usual quirks ( loses NB all the time since way back when ) it has issues with cpu multis on thuban, issues with ht multis on athlons, and i forget what it had issues with on 965 but i know it had some problem.
over 300 HT is an issue as well, and it hates with a passion gskill pc 9600 1200 c5 ram.
K10 stat no worka. CPU multi still stuck at 4x.
this is with latest "public" beta.
@chew*
With latest "public" beta you mean 3603 right?
nope a public would be a bios listed on site in the mobo bios DL section ;)
3603 would likely be a leaked beta.
Add multithreaded memory performance issues to the list of issues.
3501 bios with a rather large amount of workarounds.
http://chew.ln2cooling.com/old%20sch...0II%202pic.jpg
http://chew.ln2cooling.com/old%20sch...r%20II%202.jpg
ok, wasn't sure what you meant with "public".
I have 3603 here.
It seems to solve the Ht >18,5 issue for Deneb CPUs. Not sure if it fixes the Thuban Multi (@ 4x) issue too since I don't have a thuban to check that right now.
I could post it if its ok. Got it from ASUS support 2 days ago
Not yet... that's the point: I'm not sure if its ok to "leak" it ^^Quote:
If you do want to leak the 3603, I would be glad to test it for the x4 multiplier bug. This bug is really getting old over here.
Can someone pls email the beta M4A79T Deluxe beta bios. 3107 sucks ass.
Hi,
no beta bios for M4A79 Deluxe?
the latest two release are bugged, with a 965 c3 the cpu frequency remains fixed to the P3 p-state, 800Mhz :(
M4A79 Deluxe
(Beta) Bios 3603
Download (Offline since 3603 can be found on ASUS FTP now)
