Oki.
This will be a little OT here, but i thought i'd share ;)
ATM i'm working on 3D models in sketchup. I've just completed a 32 TSOP DIMM (240pin). Basically identical PCB and socket to DDR2 with 8 dual-stacked NAND packages on each side. If you use quad die packages with 25nm 2-bit MLC NAND for such a DIMM, you'd get 1TB pr DIMM :)
Using numbers from another thread, you could get 11GB/s sequential read and 1GB/s write using 64 ONFI 2.1/2.2 (200MBps) channels. If you settle for 1GB/s R/W pr DIMM you could get away with 5 channels (wich coinsidentally is the number of physical channels you could get in pass-through from 48-pin TSOP to 240-pin DIMM.
I took a ss of the model:
Attachment 104897
Height-wise you can fit it in a 1U rack, and it's only 7,5mm wide (socket. 5,3mm from NAND to NAND). The lenght is 144,2mm, like a 240-pin DIMM. If you space DIMM sockets 0,5mm from eachother, you could fit 50+ in the width of a 1U rack.
