Originally Posted by
blindbox
Maybe I should start telling the issues I have. As far as I know, Edge-Detect AA takes AA=4x as 12x, and AA=8x as 24x.
AA=2x makes the driver revert it back to Box AA.
The program shows AA=4x when I select 24x, and AA=2x when I select 12x. Behavior should follow the first line of this post. I'll do an image quality test right away. EDIT: Images up.
Anyway, if you select 'let application decide'(in CCC) and select Edge Detect, when you play a Source game and select 4xAA, Edge Detect gets enabled. At 2xAA, Edge Detect is not enabled.
Btw, a disable profile feature would be nice :yepp:
EDIT: Edge Detect AA works properly from my tests. I'll be posting the image comparison soon.
In other words, disregard my post. Everything works fine. Again, a disable profile feature would be awesome. Right now I have to backup, then delete the profile, then restore it when I want to enable it again.
12x Edge Detect using RadeonPro
[mg]http://img194.imageshack.us/img194/484/dranica20100809125309.png[/img]
2x AA using RadeonPro
[mg]http://img43.imageshack.us/img43/3996/dranica20100809125419.png[/img]
