Just last night I was able to pull one 6.73, which error'd out in ~10 seconds, then was back to beta units. Then hour or so later of betas, another 6.73 popped up, which has been running for 5:32, at 94%, so should be completed with a total time of 5:53. This is on a PC running at 4.16Ghz 980X, HT ON with 12 WCG work units. 480 at 800Mhz core, 1900Mhz Mem, and with 57% utilization crunching the 6.73 WU.
I've only selected the "ACEMD" application, with the "ACEMD ver 2.0" and "ACEMD beta" unticked.
If you only want the new 6.73 WUs you can opt out of "Run test applications", but be warned that the new WUs are quite scarce, so your manager may need to spam the GPUGRID server for a while before getting a unit to crunch. I selected "yes" to "Run test applications" to receive some beta test units to keep my 480 busy whilst waiting for one of the new units to show up, which seems to be around an hour or so of betas.
