Thanks... It looks like my computer will be fire safe... :)
About 90% of my parts arrived today / I should have a few updated photos of the cooling system available tomorrow... This will be the first time I've taken any photos of it.... :up:
This machine is audacious and impressive. What a machine! I wish you to be rewarded for your efforts, really.
Wait, is that outside of the build? Or is the computer inside that rolling case? If the rolling case-thing is just the cooling, I can see myself buying something like that... it's beautiful!
The picture shown above is the pedestal which is under the main part of the computer / designed to run with or without the pedestal... Each component has been designed to work without the other just in case one fails....
http://img144.imageshack.us/img144/7881/mm1v.jpg
So how much did that bottom shelf cost hardware and all?
Wow! I can't believe I am reading this thread for the first time approximately 12 hours after I ordered the EXACT same Mountain Mods configuration as you have for this build! Glad to see I was onto something. Of course, our cooling components and methods vary greatly, but I will be learning a lot from your build. Awesome and inspiring work so far my friend. This is definitely one of the most interesting things I've seen in a while. Subscribed!
I believe it was around $1,300 - $1,400 for everything which includes the Pedestal, PSU, Coolit Parts, Wiring, Switches, Controller w/ Fans, CD/DVD Drive, Insulating Foam, Ooo and a few Extra Anodized Panels…
Thanks, I hope some of my ideas help / can’t wait to see how yours turns out... :up: You’ll love the case but hiding the wires was a challenge...
I’m flow testing today / had a pin hole in one of my hoses to include a dead pump…. I guess that’s why you should test things when you purchase them :(
Little update... Everything's up and running / had a few issues in the beginning getting the system to boot w/ 12GB of Ram installed (Quickly Resolved). Then I had major issues with condensation because the temps dropped way too low / had to reset the temps to 15C's... I was shocked to see that the coolant temps didn't drop when pushed to 4.4Ghz... :up: Even though the coolant temps stayed around 15C's the CPU idles at around 22C / 38C under load (Loop Includes: CPU / Dual GPU / NB / SB)....
The dual radiators which controls the hot side of the TEC's stayed at around 31C's (radiator intake) which is okay considering it's cooling TEC's / doesn't really affect any of my other components...
Edit:
If only I would of insulated... I could of maintained lower temps...
yes yes, i know that, i meant if there is any tubing between cpu bitspower to mosfet bitspower? or did he manged to put bitspower coupler between?
Yes, there's a small piece of tubing between the 2 compression fittings and it's just over an inch long...
http://img844.imageshack.us/img844/5605/mm3956rev2.jpg
Thanks a lot for this photo, it looks awesome, especially with extenders where you aligned the two fittings.
I will have to buy some more extenders and a few angle elbows, tho this little pieces are expensive when you are buying for whole build with few blocks planned for loop :rolleyes:
No problem, I'm glad I could help / give you a few ideas and yes the bitspower fittings are expensive... I think I've invested well over $300 worth in this loop.
Edit............
h20xide / I love your avatar :up:
Another update.... I used Red / UV Blue antifreeze in the loop... I'm thinking about using black lights to enhance the glow....
http://img209.imageshack.us/img209/5513/mm4045.jpg
http://img209.imageshack.us/img209/687/mm4086.jpg
http://img209.imageshack.us/img209/1742/mm4116.jpg
http://img209.imageshack.us/img209/7071/mm4120.jpg
http://img209.imageshack.us/img209/7396/mm4125.jpg
http://img209.imageshack.us/img209/4797/mm4148.jpg
http://img209.imageshack.us/img209/2962/mm4152.jpg
This is sex.
Complex machine, wrapped with a little of mystery. Nice the association, the dynamism of the blue and the red. I like this universe :)
As mentioned before I'm getting ready to move and I'm guessing it'll take approximately 2 months before I'm able to continue my work - until then...
Thanks again for your continued support............
You're an animal Mal. Beautiful build.
