As an added note I was able to replace the stock water block on anther sealed loop cooling system (an older Coolit Freezone Elite which uses TECs to chill the coolant) with a NB water block that came with a Gigabyte board I had without significant change in performance so opening sealed loop systems outside of the factory can be done, my question is can this one be closed again basically and still run. Thanks
