Originally Posted by
Solus Corvus
I'm a bit disappointed that AMD made the same mistake that they made with the 4000 series. The furmark issue was one of their biggest pr blunders of that generation and I had figured AMD is a company that can learn from its mistakes. Maybe they will finally learn with the next generation.
But, IMO, the VRM problem isn't as big of an issue as some people are trying to make it out to be. For the vast majority of users this is going to be a total non-issue. It plays most games and runs most GPGPU apps just fine, even overclocked. For those who are concerned about running these particular apps or long term reliability then they have plenty of other options. They can wait for a 4 phase version, get 2 5870s, watercool it, or save their money for something else. Nobody is making you spend a huge wad of cash on something you feel is inadequate.
Also, comparing a 295 to a 5970 is laughable. Try comparing a 295 to a 5870 instead. They have about the same performance but the 5870 costs less, doesn't have multi-gpu issues, dumps less heat, consumes less power, overclocks higher, also has 4 VRM phases, and software voltage control - not to mention supports DX11, etc.
