Very nice noeru, fantastic work and photos! :up:
noeru i just love your bild you even made me buy the same case. Great work man
Mid Night2 800D BLOOD+
Attachment 100073
Attachment 100074
Attachment 100075
Attachment 100076
Wow, this is such an inspiring build! congratulations on finishing it, I have been watching this for weeks!
looking very nice m8.
hello thank you for watching my work:)
Close Case room temp 18.5℃ Water temp19.5
try to the max clock:rolleyes:
Attachment 100150
Wow, Extremely Nice mod. You done a great job. Oh you pushed your cpu to nearly 5ghz. Could you mind to tell me what is the temp of ur cpu at 5ghz?
thanks^^ Image is small
Attachment 100151
Nice build. :)
I wonder if it's possible to fit HWLabs Black Ice GT Xtreme 560 monstrous rad (153mm/605mm/54mm) in top of Obsidian 800D in similar way?
Hi churchy I think I have a GTX560 this "800D" in order to achieve cut the front panel must
this case is External dimension is 585m/m
Attachment 100175
Attachment 100176
Attachment 100177
Attachment 100178
Big thanks for info/measurements. But how about cutting back of case? So eg. non fan part of rad with tubing attachment holes is outside case (it won't change much looks as it's well .. back :) ) .. IIRC there should be some place for optional top PSU mount? And how about internal width of 5.25 bay enclosure? Can you measure that width of enclosure if it's wide enough to put 153mm wide rad in there or needs to be removed (I don't plan using any 5.25" devices anyway) + if possible, pics of top-back of this case from outside&inside?
P.S. There is another monstrous radiator out there (Watercool Mo-Ra 2 Pro, square form (424 x 385 x 54mm) 3x3 for nine 120mm fans which i considered at one point for installment on the side of case, even quieter and better cooling then gtx 560), or similar Phobya Xtreme NOVA 1080 rad, but most probably installing those will result in ugly looking side of case with fat bump outside dimensions). But in any case .. how wide(deep?) is compartment on the right side of case for cable management?
http://www.hwlabs.com/images/gtx/d_gtx560.jpghttp://www.coolputer.fi/tuotekuvat/1097.jpg
Hi churchy this rad I think this is difficult. Process also requires a five-inch side of the bay
the inner bay is 5 inches 146.8mm.
I was set 15mm further back than normal
Attachment 100188
Attachment 100189
Inner 5.25 bay Front top
Attachment 100181
Attachment 100182
Attachment 100183
Attachment 100184
Attachment 100185
Well, seems i'll have to give up on this particular rad and use some 3x140mm or 4x120mm as one you used, as i am aiming to maximise cooling but still staying with everything mounted within case. Thanks for providing info, it will help me greatily with choosing components.
Arigato gozaimasu :)
P.S.
Pitty though. Almost none of current full tower cases by major vendors seem able to accomodate gtx 560. Maybe sometime in future in some next iteration of their cases ..
Churchy, well I have the PSU on top, I had to drill several rivets to get the roof off... but I use a Lian-Li PSU Extender too :)
I'm buying a new cam tomorrow so until then no pics unfortunately :)
That's how I got 2 Quad rads in the bottom compartment :)
Nice clean looking setup
Subscribed:up:
veryvery Thanks:)
There are also some pictures here
I'm noeru:welcome:
