Originally Posted by
kgtiger
If you have any questions, please feel free to ask me, I am more than happy to share knowladge and idears.
On that line of asking questions. Does anyone know where you can buy the rotozip RZ20-4500 in Australia?
I have only looked on line, however without any luck.
Great to know, thanks. :)
Have you tried locating an RZ on ebay? Sometimes sellers will ship internationally.
Alright, I have some more updates. None of this is sexy stuff. No power tools or pretty renders. But let's not fool ourselves. Putting together a nice build is not all glitzy and glamorous (or the adrenaline rush that you get from drill presses, jigsaws and rotozips); sometimes it's just good old-fashioned elbow grease that gets a certain job done. And that's what you're going to see here.
I showed a few pictures in the last update of the solid panel that I received from Cooler Master for the waterjet graphic. When I pulled it out of the box, to my great dismay, it had that dreaded foam soundproof material covering most of the panel.
http://img23.imageshack.us/img23/121...ionbuild41.jpg
I knew I wanted/needed to remove this to prep it for the waterjet cut as well as removing the square frame which is used to mount the panel to the support rod interior latches that I showed before. In fact, I plan on modifying the panel even further by swapping the frame that was on the stock panel with the frame from the new panel. Why do this? Well, as you can see here, the frame on the stock panel is actually cut into 4 sections whereas the new panel frame is in one piece.
http://img11.imageshack.us/img11/723...ionbuild39.jpg
Since I want to relocate those support rods closer to the roof of the case, it would be much easier to simply raise that top portion of the stock frame an inch or two. I couldn't raise the entire frame because then the bottom groove would not line up on the panel.
In this shot here where I'm detaching the new frame, you'll see what I'm talking about. Notice the bottom grooves that are cut to allow the bottom of the panel to mount easily to the case.
http://img193.imageshack.us/img193/6...ionbuild42.jpg
If you're keeping a case stock, this is a very trick and seamless mounting solution. Works really well. But if you plan on modding the case extensively, it's a pain in the padded *#^. I've already spent more time than I'd like trying to work around this mounting mechanism, but I digress.
http://img39.imageshack.us/img39/427...ionbuild43.jpg
Ugh.. this won't be fun. I had to peel pretty hard to get just that corner up, and it's leaving a lot of residue and padding behind.
http://img9.imageshack.us/img9/2154/...ionbuild44.jpg
I can't tell at this point whether this is beginning to look like a kindergarten fingerpainting or a greasy mechanic's welcome mat. Either way, I've spent about 30 minutes by this point trying to peel this crap off.
There has to be a better way...
And there is. I know the exact tool for the job (just wish it'd hit me 30 minutes earlier..)
http://img203.imageshack.us/img203/5...ionbuild45.jpg
Goo Gone. For sticky situations where you'd like to keep:
A) Your fingers in their joints
B) Your fingerprints
C) A few hours left in your day.
And as you can see, it's doing the job much better. The trick was to spray the padding repeatedly at its contact point as you peel the foam away, and as you can see now it's peeling away in one piece and leaving little residue behind to clean up later.
http://img30.imageshack.us/img30/742...ionbuild46.jpg
Almost there...
http://img39.imageshack.us/img39/942...ionbuild47.jpg
http://img193.imageshack.us/img193/3...ionbuild48.jpg
And, it's finally off. That's the good part. The bad part is that there's a lot of glue and residue left behind.
I began looking around for the right tool to remove the glue with, and what better tool for the job than a straight razor.
http://img18.imageshack.us/img18/613...ionbuild49.jpg
With this, I'm able to slice right underneath the glue and pull most of it off in sheets.
http://img140.imageshack.us/img140/9...ionbuild50.jpg
Halfway there. It's been about an hour and 15 minutes and I can actually see the finish line by this point.
The rest went by fairly quick, and here's the finished product. A nice, shiny aluminum side panel, foam-free and waterjet ready. If you're wondering about the inserts, they're used to hold in place and screw down the mounting frame. I removed the bottom two at the top tonight to make more room for the side panel graphic. Shouldn't pose much of a problem, from what I can tell.
http://img30.imageshack.us/img30/380...ionbuild51.jpg
A look at all the glue that I had to remove...
http://img193.imageshack.us/img193/2...ionbuild52.jpg
And into the trash that goes.
Some time after that, the case was stripped down and the legs and outer shell were removed.
http://img109.imageshack.us/img109/4...onbuild54o.jpg
http://img175.imageshack.us/img175/2...ionbuild55.jpg
http://img30.imageshack.us/img30/645...ionbuild56.jpg
In the next few days, I'll be drilling out the rivets and prepping it for some cutting. I received notice today that my RotoZip is on its way, so I'm keeping my fingers crossed that it arrives before the weekend.
Thanks for checking in!
