Turbo enabled overclock with C-State and C1E
I was doing a similar overclock on my X3440 and thought I would give it a try on my i5.
1.375v vcore set in BIOS with vdroop (LLC disabled) 181x21 turbo enabled (4 threads) and 181x24 (2 threads) with C-State enabled. In effect you get a 4.3Ghz dual core and a 3.8Ghz Quad. If you want to try this type of overclock I would recommend leaving C1E disabled at first to dial in your voltages for stability. With C1E enabled your voltages can drop quite low (0.988v) and will spool up on demand. You do need more vcore to stabilize the x24 multi then is required to run 4 cores at x21 multi. In my overclock at 3.8 I'm showing 1.352v/1.364v load in CPUZ. My board overvolts with C1E enabled and will show as high as 1.399v/1.411v in CPUZ while running SuperPi 1M and 32M.
http://i695.photobucket.com/albums/v...i575043ghz.png
