I will test my ram.
I will test my ram.
Comparing to Brian's results is frustrating most of the time... :D
On the other hand it's a great source of motivation chasing his scores. I hope to do that with a C3 some day. :)
32M on AMD... *yawn* I was half asleep after a run finished, it's even worse if a run crashes after 2/3 of the time... :rolleyes:
Alright man, thanks for the tip.
I just don't understand what was stopping me this afternoon as i know for sure the first kit i tried can do 956 easy with the timinings i used.
Off to try more volts now. :D
*edit*: More volts didn't help, memtest 86 test 5 freezes immidiately at DDR 1800. :shrug:
What Memory you using Zeus ?, keep at it, you will get it.
Gonna spend some more time with it tuning things then but it's not that important to me, i was just trying to find the IMC max. ;)
Neo mike, it's CSX Diablo ram with Micron D9GTR chips.
Does this seem right?
Everything is in stock setting my setup is in the sig.
I am wondering if the FSB : DRAM ratio is off?
http://i176.photobucket.com/albums/w...9/Garu_mem.jpg
Just set ratio manually.
The ratio should be set to 1:1?
Depending on what speed you want to run them at. Set 3:10 for 1333 or 1:4 for 1800. 1:1 is not suitable for amd set ups.
test the new g-skill 1.35v kit on am3 yet????????
http://www.newegg.com/Product/Produc...82E16820231321
Look at this: :eek:
Problem with that corsair ram, its good ram, but over the top on price $350 for 4 gigs of 1600, cas 6 out of my reach cash wise.
what clock and timings?
Here you go mate! ;)
Fastest offering seems to be a set of 4GB DDR3-1600 CL6.
I like the green, it's a nice addition to the existing red colour theme, if only they made the fins in yellow now.... :D
Not much info on this ram yet:
http://www.corsair.com/products/phenomii/default.aspx
:shrug:
hm,its not bad, good choice for Thuban PC maybe :)
i just order the Dominator GT's Cas 8 flavor at 2000mhz, i will post results once i get all my parts and have it setup
Dragon
Might be a new flavor in town.
GTX 2250's incoming.
Rated 1800 6-6-6 on amd, my guess is mobo dependant.
