I can't say yet, due to lack of manufacturer information on this model.
Think I'll put the EK in parallel with some SLI VID connectors.
Heatkiller should have blocks in about two weeks.
Which according to google means roughly "The cooler is planned for the next 14 days."Quote:
Originally Posted by Rico
That was on the first, so we might see something in a little over a week from them.
I don't suppose anyone knows the length of a 5870 naked? I've seen a number of reviews mentioning 10.5" or 11", but they never say where they are measuring from (i.e. just the PCB or right to the back of the case) and I'm not sure that it'll fit into my Lian Li 343 case...
Just info on EK 5850 Blocks. I just confirmed the desing and tomorrow block goes into production.
First pieces of 5870 blocks will be shipped on friday.
Koolance blocks will be available Friday! 5850 block is also coming up!
BP has also got a block lined up, With the usual BP quality i would expect this to be once nice piece of kit. I have some renders and a little bit of Info for you guy/gals.
http://i255.photobucket.com/albums/h...1024X768-1.jpg
Black Freezer (Black)
1.Design for Ati 5870/5850 Reference Design VGA Card.
2.Direct-Flow Design On Inlet/Outlet.
3.Included SLI Adapters / Fittings.
4.Stand-Off / EZ-PLUG Design.
5.TOP Cover Made Of POM.
6.Block Base Made Of C1100.
7.Cross-Fire Ready Application.
8.Bottom High durability Nickel finished in Black.
9.Matt Black Panel Fixed
10.RoHS Compliant.
Black Freezer (Sliver)Quote:
1.Arctic Silver 5 3.5G X 1
2.Fujipoly GR-d
3.Backup O-Ring for VG-A5870 x 1
4.Black Sparkle Rotary Angel IG1/4" Adapter x2
5.Black Sparkle Direct-Plug Adapter x 1
6.Black Sparkle Direct-Plug Adapter - 35MM Version Female Part only x 1
7.Mounting Screws/Accessories -EZ-PLUG Mounting Ready now.(PAT. Pending)
9.Polished Stainless Panel Fixed
10.RoHS Compliant.
2.Fujipoly GR-d
So the Bitspower block will workon both the 5870 and 5850?
wow BP block looks epic
block should be separate btw hence the name on the front, think its likely pretty dam similar though
kinda like EK's block, designed the same, just making it accomdate the diff card :)
Yes Baulten that is correct :)
BP matt black blocks should have gold logo like there new blocks for x58 classified x3 & x4 ;) .
Sweet; I'm still deciding between cards... I'll probably go with the 5850 is a full cover is available soon.
AquaComputer looks like they're coming to the party.
http://shop.aquacomputer.de/images/p...ages/23478.jpg
Renders only at the moment, and I'm not entirely sure what "kurze Lieferzeit" translates to, so it may be only in pre-order stage at present, although the description below mentions nothing to confirm.
I am hoping that the Heatkiller blocks use the same connector design for CF that their GT200 blocks did. It just makes it so much cleaner and simpler than messing around with tiny barbs and short hoses or D-plugs.
SoulsCollective, you are far behind :D
The delivery of the aquagratix HD5870 starts tomorrow. At the moment it can be ordered for a special price of 69.90 EUR (~87.00 USD w/o German VAT); later it will cost 79.90 EUR.
Special Crossfire connectors will follow in the next days so you don't have to fumble around with bent connectors and tubes.
The technical facts:
- electrolytic copper base
- slotted structure above the GPU
- special polish for the GPU and RAM surface
- spacers for mounting at the VRM site
- stainless steel cover with laser engraving
- plexiglas connection terminal with G1/4" threads in both directions
And a few pics:
http://forum.aquacomputer.de/images-ac/5870_1.jpg
http://forum.aquacomputer.de/images-ac/5870_2.jpg
http://forum.aquacomputer.de/images-ac/5870_3.jpg
http://forum.aquacomputer.de/images-ac/5870_4.jpg
http://forum.aquacomputer.de/images-ac/5870_5.jpg
http://forum.aquacomputer.de/images-ac/5870_6.jpg
Hey, to the best of my knowledge this is the first time this has been posted here - so blame your publicity dept :p:
This was actually one of my concerns - the product page tells us "Crossfire compatible when equipped with bent plug&cool fittings (Art. 90006)", which refers to these 90-degree elbow fittings. This combined with the limited renders shown on the product page led me to think that the AQ block was only threaded on one side, which would make plumbing Crossfire setups ridiculously difficult and was a deal-breaker for me. Looking at those above piccies, though, it looks like you could plumb each side of the block, and thus have a straight run between blocks in Crossfire without messing about with elbows. Correct?Quote:
Right :)
Excellent. You might want to fix your product page then, before anyone else is similarly misinformed - you in fact do not need the 90-degree elbow fittings to use these blocks in a Crossfire setup.
