http://www.techpowerup.com/reviews/S...front_full.jpg
I see 5 Phases GPU and 2 Phases Mem... :confused:
There are 3 phases for the MAIN CORE
2 phases (NEXT to the 3 core phases - 1.2Volts) for another circuit inside the core (VTT?)
1 phase for the MAIN RAMS
1 phase for rams VTT
1.82Volts for the Core (VTT?)...
PLUS Rivatuner VT1165 can provide you UP TO 1.45Volts REAL....
EVEN if you pick 1.7Volts, it gives you 1.45Volts REAL and that's it...
TIP for guys under LN2
USE ONLY the 850, 900, 950, 1000, 1050, 1100, 1150, 1200, 1250, 1300 as for the core and ALSO every 50MHz as for the rams
The XTAL oscillator on these VGAs (and the 4870 series) it's NOT 27MHz so to go every 27MHz step...
It's 100MHz, so NOT to get into problems, follow the RULE every 50MHz step... :D
For example - DON'T put the core 1070MHz....Put it at 1050 OR 1100... ;)
Thanks for the insight Hipro :bows: :up:
good information hipro5, thanks :up:
Thanks for sharing Hipro... very interesting.
Those two phases are for memory controller in GPU. You need to raise that voltage as well, if you like to clock your memory well.
This bios does fix the limit, but it does not make any card to clock better. I think this is what people have missed in here.
Bios is from ATI engineers, so I am not talking crap here. We need to find the issue, which holds us back after 1250MHz clocks and no, it is not voltage.
Mod the card George, it will help for sure. Let's hope, that cores will scale well in your tests :up:
Excuse me?...How high do people want to bench with these cards and there is a problem?.... :confused:
If 4870 did ~900MHz on air and ~1150MHz under LN2, then this one must have core limit ~1250 - 1300MHz... No?... :confused:
Thanks Petri... I'm "almost" benching 1100MHz on air with one of them (the first I touched) the 2k6 canyon flight...1050MHz does it very easy... :)
It's not voltage AND not temperature ... :(
thanks hipro5 (george)!!
So is it time to crystal mod hardware again? :D
FWIW I've ran 4890 at 1272MHz through 01 nature, and yes it did score higher than 1250. ;)
But, I'll let all you experts proceed. :p:
ned vmod/high clock to CCC;) softmod :down:
i am not sure i sure about that george
at least the testing i've done with a couple of cards didnt seem to follow your rule
have a look at card clocks mentioned and how it went up with volts while i was testing 01
http://www.xtremesystems.org/forums/...d.php?t=222421
i could and have seen improvements in smaller jumps
:shrug:
any example with lower clocks that i can test myself? ;)
are you jumping directly to that clock from stock or are you moving in steps?
try if moving in smaller steps to that frequency helps
