The point isnt to get a cooling solution as good as a triple fan rad setup, just to beat air coolers by a significant margin, as it installs as easily as one, and allows the same freedom air cooling has as far as maintenance and part/case swapping.
There is always something better. Ofcourse a triple fan custom setup will outperform it, but its much more hassle and swapping parts/cases becomes a nightmare.
Why not just hook a hose from the tap into the inlet of your CPU block, and a hose leading back to the drain from the outlet and turn on the cold water whenever you wanna use your CPU, it will make your setup look like garbage :P
Practicality plays a part in things.
