ohh man, this is great. one of the nicest rigs ive seen so far. Love the white water blocks :up:
so i got some new pictures but the quality is very bad. and i dont have any programm to konfigure the picīs. so i say sry for the bad quality but i dont want that u dont know what happend.
http://www.abload.de/img/dsc01890h54m.jpg
http://www.abload.de/img/dsc01894f68i.jpg
white white white :)
love the attention to detail.
White enhances the existing colors and red hues overlaps over other colors
i have deletet the bad pictures because i want some good one. i went downstairs. took the rig get it in position an tadaaaaaa
http://www.abload.de/img/dsc01906d5cv.jpg
http://www.abload.de/img/dsc0190870zd.jpg
Hey what kind of light are you using that's thin enough to be back there?
CCFL or LEDs?
what are you using something like this?
http://www.lamptron.com/product.php?p_id=48
or are you just using a tube?
beautifully placed lighting :up:
im using smd led stripes from neuhold elektronics. in a cold white.
http://img1.abload.de/img/dsc0189531b0.jpg
and i got my ram back to stockcooler because it looks much better
before
http://www.abload.de/img/dsc01912oucy.jpg
after
http://www.abload.de/img/dsc01914etce.jpg
here u see the difference
http://www.abload.de/img/dsc01913iuda.jpg
paint those arctic rc in white :)
like this one ?
mdpc - mpc case
yes and like this one :)
mdpc - tremelos case
u have seen it 2 times why a 3rd time ? ;)
because all good things are 3 ?! :D
the problem is i dont have white color anymore. i got it special from a painter. because in my city i dont get any spraycolor in ral 9016 onlz ral9010 so i must went to my painter and get the color again.
and it's white :D
but you know what's the best for your system :)
As you say, it's been done twice before, maybe just paint the silver clips on the new heatspreaders black? That could look cool :)
you spy right :P but what is in that package ???
http://pic.leech.it/i/19e65/e4f3e3afoto1.jpg
dam dam dam dam dammmmmmmmmmmmm :)
I would assume something that cost 50 Euros? :shrug:
Something that should not bend?
it cost 20euro and i got it from a friend. he bring it today to the yellow man called POST and i hope i have it in 2 days :)
but today i got this one
http://www.abload.de/img/dsc01933l4aw.jpg
i was unhappy with my PSU color so i decidet to do a paintjob
http://www.abload.de/img/dsc01935e1u8.jpg
me again
http://www.abload.de/img/dsc019374frg.jpg
i love this tool so much
http://www.abload.de/img/dsc01940dd7c.jpg
What power supply do you have that has such long cables!?
Whats the case? (A silverstone or Lian Li right?)
What did you use to cover all the cables with? (referring to the white shoelace looking stuff) and where can I buy some?
How did you cover every individual whire coming from the Power supply? Like normally you see the whole bunch of each modular piece wrapped up, not the individual wire. Do you have to take the ends apart to get the sleeves on them? I really want to do that, but if you have to take the wires apart, then forget it :(
its a enermax modu82+ and i have customize the cables.
its a tj07 with murderMod Parts thats get a white powdercoat.
i sleeved the cables. if u want this to do u must push out every pin from the connector. and sleeve cable for cable. you don have to open the PSU u can still sleeve only 10cm ore more ore less. its on you. i have buy it on mdpc-x there you get the best of the best of sleeve.
i hope a could help you see ya
