Derlin sounds sweet Q...can you do it?
The Delrin should come out to $.65 a disc...which isn't very bad if I can cut them myself.
Eh acrylic would be good too if you already have it. I'm not fussed at all.
Hey Q,
Might just be a good idea to make the ones that you can right now as first described, before you get too backed up ;)
Maybe you can then back a revision and offer the delrin and what not when you get caught up on this orders and also offer the helixs and delrin caps as replacement parts.
The people that want to change things up can and those that are happy with what the have don't have to :up:
where my reses ;) should I put one in this build (rough layout for HTPC)?
http://img269.imageshack.us/img269/9...center6488.jpg
That has to be the biggest HTPC I've seen lol. The matx board . .. . is dwarfed.
I hope one of those are mine! They do look sweet man. I can't wait for you to have the colors side by side to show how they look. Yeah, the Derlin does sound good. I have one of the derlin tops for my Dtek CPU top.. I love it!
Looking good man, looking good.
Oh man, I want one so badly. Gotta find something not to buy so that I can buy this one. :D
Frozen.Q: You are a genious. :D
TBH, I'm kinda wishing you could do a purple one! :P
I wanted to personally, but I cannot find purple UV reactive acrylic
Ah yeh I am sure it is quite rare :P
I could just do transparent purple and use a white cathode...not sure how that would turn out though.
Kind of weird but can I specifically request to have the acrylic end discs?
Well, all the orders now are getting polycarbonate ends. They are all painted though. Delrin will happen in the future.
Ahh ok, it's not a huge thing anyway lol.
Still time to modify my colors? Two UV blue twists with Dark blue caps and two with UV green twists with dark blue caps please, STAT.
Sure sure...I will see what I can do = )
Very nice. If I hadn't just bought the typhoon IIIs, I would definitely want one.
dude you better hurry . . . can't wait . . . .I just
http://www.youtube.com/watch?v=D-BD8aj5HyU
