Hello.
I recently installed Windows 6 64 bit and now the program works!
However, I want to use three states or more, because my overclocked state got some higher vcore than the unclocked one, obviously.
W7 x64
Phenom 2 x4 940
I downloaded this modded version:
http://www.hardwareluxx.de/community...&postcount=171
Seems to work well, however, I don't understand the "Overall CPU load threshold" options, here they arem the different states are called Low, Middle and High:
Overall CPU load threshold (%) high/low: 24
Overall CPU load threshold (%) high/middle/low: 24
Overall CPU load threshold (%) middle/low: 24
Could someone explain the differences? Right now my states are at 800 MHz, 3 GHz and 3.6 GHz, and when idling or just using the webbrowser it constantly jumps between state 1 and 2, which shouldn't be needed.
I used K10Stat before, which I rarely had to jump to state 2. And it doesn't make sense that it should, 800 Mhz is plenty for that.
Anyone who might have an idea?
