mh yeah that would be enough atm...let's see which version i should take ^^
I'd work with build 1900 and work your way up.
I'm using the 1847. was the first one I found on my pc.
works perfect so far :)
EVEREST Ultimate Edition 5.30.1973 2009-12-17
* detection of ATI Catalyst 9.12 driver
* identification of AMD Athlon II M3xx (aka Caspian)
* identification of AMD Sempron M1xx (aka Caspian)
* identification of AMD Turion II M5xx (aka Caspian)
* identification of AMD Turion II Ultra M6xx (aka Caspian)
* identification of Intel Core i7 Extreme 980X (aka Gulftown)
* identification of Intel Xeon E56xx, L56xx, X56xx (aka Westmere-EP)
* identification of Intel Xeon W36xx, W56xx (aka Westmere-WS)
* Intel Processor Number detection for Core i7 Extreme 980X
* Intel Processor Number detection for Xeon E5503, E5507, E5620, E5630, E5640, L5609, L5630, L5640, W3530, W3680, X5650, X5660, X5667, X5670, X5677, X5680
* Display / GPGPU / detection of max work-item size (OpenCL)
* Display / GPGPU / detection of max work-group size (OpenCL)
* Display / GPGPU / detection of memory base address alignment (OpenCL)
* Display / GPGPU / detection of min data type alignment (OpenCL)
* SPD memory information for Asus IPP7A-CP motherboard
* SPD memory information for LG ED310-M notebook
* sensor support for Dell SMI of Studio 1735, Studio 1737
* fixed: motherboard specific sensor info for Gigabyte 73PVM-S2H
http://www.lavalys.com/beta/everestu...d2fsqlk9yx.zip
Still locks with 5970.
yep, same for me
EVEREST Ultimate Edition v5.30.1977
* Hardware Monitoring / CPU diode temperature support for up to 8 cores
* Hardware Monitoring / new item: PCH temperature
* GPU information for Intel Ironlake, Ironlake-M
* RAID member enumeration for HighPoint RocketRAID 26xx RAID controllers
* physical CPU information for Intel Arrandale, Clarkdale
* Intel Processor Number detection for Core 2 Duo P7570, Core i7 810
* chipset information for AMD M785 (RS880M)
* SPD memory information for LG H23L notebook
* GMCH temperature measurement on Intel Ironlake, Ironlake-M
* PCH temperature measurement on Intel Ibex Peak
* motherboard specific sensor info for Asus P6X58D Premium
* motherboard specific sensor info for Supermicro C7SIM Series
* improved motherboard specific sensor info for ASRock boards
* fixed: DRAM:FSB ratio detection for Intel Ironlake, Ironlake-M
* fixed: CPUID / processor name label width
* fixed: motherboard specific sensor info for Intel DP35DP
* fixed: CPU diode temperature measurement on Intel CPUs with HTT & 64-bit OS
EVEREST Ultimate Edition v5.30.1983
* Hardware Monitoring / new items: GMCH, GMCH1, GMCH2, OPT1..OPT3 temperatures
* USB-IDE bridges support disabled on Kingston DataTraveler flash drives
* SPD memory information for Asus E60 motherboard
* SPD memory information for Asus Eee PC 1201N
* SPD memory information for Foxconn nT-230i
* SPD memory information for Foxconn nT-330i
* SPD memory information for MSI Wind Top AE2020, AE2220
* SPD memory information for Zotac IonITX-G-E motherboard
* chipset information for Intel Pine Trail NM10
* chipset information for Intel Westmere IMC
* preliminary chipset information for Intel Pineview IMC
* sensor support for Dell SMI of Precision T5500
* motherboard specific sensor info for Gigabyte H57M-USB3
* GPU information for Intel Pineview
* improvements under Parallels Desktop
* fixed: GPU information for Intel Bearlake-G, Bearlake-Q
* fixed: OS / OS / Windows Live Messenger version detection
* fixed: TJMax temperature adjustment
* fixed: lockup on ATI CrossFireX systems with ULPS enabled
Still hard locks the system for me and my 5970 and I manually disabled ULPS.
Everything on gpu1 goes blank and it locks.
http://www.xtremesystems.org/forums/...&postcount=100
EVEREST Ultimate Edition 5.30.1990
* Storage / SMART / special support for Intel X25-M G2 SSDs
* identification of Mobile Intel Core i3 (aka Arrandale-3M)
* Intel Processor Number detection for Mobile Core i3 330M
* Intel Processor Number detection for Mobile Core i3 350M
* Intel Processor Number detection for Mobile Core i5 430M
* preliminary chipset information for Intel Pineview-M IMC
* GPU information for Intel Pineview-M
* GPU information for new nVIDIA GeForce 9500 GT (G98GT)
* sensor support for Dell SMI of Studio 1536, Studio 1736
* motherboard specific sensor info for Gigabyte 790FXTA-UD5
* motherboard specific sensor info for Intel DP45SG
* fixed: SPD information for Noname 128M PC133 modules with bad CRC
* fixed: SPD information for Noname 256M PC133 modules with bad CRC
* removed: Gigabyte DES support
Why DES support removed?
Showed ~4 times higher value.
http://www.lavalys.com/forum/index.php?showtopic=4432
oh ok so its coming back someday...
Everest Ultimate Edition 5.30.1996
* SPD memory information for Asus IPP9A-CP motherboard
* motherboard specific sensor info for Asus P7H55-M Pro, Asus P7H55D-M Evo, Asus P7H57D-V Evo, Asus P7P55D-E LX, Asus P7Q57-M DO, DFI LANParty BI P45-T2S Elite
* fixed: motherboard specific sensor info for Asus P7P55 Series, Asus Sabertooth 55i
* fixed: support for 512 bytes PCI device blocks on AMD K10, K11 processors
* fixed: CPU clock measurement on AMD K10 & K11 (using perf.counters)
Everest Ultimate Edition 5.30.1999
* improved identification of AMD K10 processors with disabled core(s)
* GPU information for ATI Mobility Radeon HD 5730 (Madison)
* GPU information for ATI Mobility Radeon HD 5850 (Broadway)
* GPU information for ATI Mobility Radeon HD 5870 (Broadway)
* GPU information for nVIDIA Quadro FX 2800M (G92GLM)
* extended GPU information for ATI Juniper, Redwood
* extended and fixed GPU information for nVIDIA GT21x Series
* GPU utilization measurement for nVIDIA GPUs
* video memory utilization measurement for nVIDIA GPUs (Vista+)
* sensor support for Dell SMI of Vostro 1200
* motherboard specific sensor info for Gigabyte H55, H55M Series
* motherboard specific sensor info for Lenovo IdeaCentre B500
* fixed: Intel Processor Number detection for Mobile Core i3 350M, Core i5 430M
* fixed: HDD temperature measurement of disconnected external drives
* fixed: motherboard specific sensor info for Asus P7H57D-V Evo, Asus P7P55 Series, Asus Sabertooth 55i
Something wrong with few latest Everest betas.
Seems to freeze whole computer if using two Ati cards :o
I submitted a system report as it wasn't detecting my new MSI Wind U130 Netbook with 1996...with 1999 it now reports my Netbook :-)
EVEREST Ultimate Edition v5.30.2004
* Motherboard / CPUID / Turbo Boost multipliers detection on non-XE CPUs
* physical CPU information for AMD Sempron 1xx (aka Sargas)
* HD Audio codec information for ATI Redwood
* SPD memory information for Alienware M17x notebook
* motherboard specific sensor info for Asus M4N78 Pro
* motherboard specific sensor info for Gigabyte H55M-S2H
* fixed: AMD Brand ID detection for triple-core & quad-core processors
* fixed: video memory utilization measurement for nVIDIA GPUs
* fixed: Display / GPU / nVIDIA ForceWare clock information (196.xx+)
Well, i've noticed that there are not many AMD m/b's with AMD/ATI chipsets among the m/b's added for sensor detection.
Is there a specific hardware lach of features or is it based on Intel/AMD user statistics ? Just curious, no attitude in my question.
EVEREST Ultimate Edition 5.30.2009
* identification of Mobile AMD Athlon Neo X2 L3xx (aka Congo-256)
* identification of Mobile AMD Turion Neo X2 L6xx (aka Congo)
* improved support for VIA Nano
* VIA Processor Number detection for Nano L1900, U1700, U1800, U2250, U2350
* SPD memory information for ViewSonic VOT132
* identification of DDR3-2333 memory modules
* HD Audio codec information for ATI Cedar/Park
* motherboard specific sensor info for Gigabyte X58A-UD3R, Gigabyte X58A-UD5, MSI MS-7576
* preliminary GPU information for ATI Mobility Radeon HD 5470 (Park)
* fixed: motherboard specific sensor info for Gigabyte 790FXTA-UD5, MSI MS-7599
EVEREST Ultimate Edition 5.30.2018
* optimized bitmap display on Logitech G15/G19 keyboard
* MonDiag / mouse wheel to scroll between test screens
* detection of ATI Catalyst 10.1 driver
* USB-IDE bridges support disabled on MS Zune
* Intel Processor Number detection for Core i3 550
* Intel Processor Number detection for Core i5 680
* Intel Processor Number detection for Core i7 880, 970
* improved support for Intel Arrandale, Clarkdale
* preliminary chipset information for nVIDIA MCP89
* SPD memory information for Zotac IonITX-F-E motherboard
* SMBus support for nVIDIA MCP89
* SMBus controller enable on Intel NM10
* HD Audio codec information for nVIDIA MCP89
* GPU information for ATI RS780E, RS880P
* sensor support for Dell SMI of Vostro A860
* motherboard specific sensor info for Asus P7H55D-M Pro
* fixed: phantom OSD items when Logging is enabled
* fixed: ODBC drivers version detection under 64-bit Windows
* fixed: processes list under 64-bit Windows
* fixed: motherboard model detection
* fixed: SPD information for Nanya modules with bad CRC
* removed: workaround for nVIDIA ForceWare clock information (196.21)
Thanks for the updates Stasio!
Latest beta versions remove this values.:(
http://i45.tinypic.com/2itsj6t.jpg
