Auto, but the fan will hit 100% sometimes if I run multiple loops of some benchmarks.
evga ssc @ 1.20v
my ssc @ 1.23v
vmod @ 1.26v
no oc gain
vgpu mod does not work on the ssc until ovp is removed/increased
so if anyone could/would share that would be greatly appreciated
Got my card yesterday, haven't tested thoroughly, but 756/1620/1476 was 15min furmark\Warhead bench stabe when I kept temps. around 65-70c. But would crash/blank screen when I was hitting around 85-90c.
Gonna put it on water in the next few days, so those clocks should be perfectly stable, and maybe Ill even get a little more out of it :)
yeh @ 15k resistor no boot
From my experience, there are two benches you can use to check stability with great accuracy.
3DMARK06 at 1920x1200, 4xAA, 16xAF, run the 4 main graphics tests 3 runs each, exclude the CPU tests. If it passes all 4 of those tests 3 times back to back without any artifacts or crashes, it's stable.
Crysis Warhead benchmark 1920x1200, queue Ambush, Avalanche, and Frost to run back to back. If it passes all three of those without any artifacts or crashes, it's stable.
I use both when testing my overclocks and both have been VERY reliable.
I'm consdering water cooling myself as well as I've water cooled my last 4 graphics cards. I'm waiting to see the 285 FC blocks and prices before I jump. I may just leave this one on air since overclocking beyond what I've achieved so far is just for bragging rights and not likely to give much of a boost in real gaming, just benchmarks. I'm trying to keep cost down on this video card upgrade until the next gen hits later this year which should be a much larger upgrade.
Would be nice to see minimum fps with SLI...firingsquad review has it for 2 of their benchmarks which is odd...maybe the numbers were just unflattering for Crysis.
