Totally sick NB clocks. I'm sure that really helped the clock/clock efficiency.
what made you guys use the dfi instead of the gigabyte/referance boards you guys used at the preview events?
There was no particular reason for using DFI, but we got our NB clocks and 3D performance up with that mobo. It is a good choice, if you plan to go with AMD.
I found 6.5GHz picture:
Attachment 92970
What a shame, that validation was broken..
DFI and AMD go to together like apple pie and vanilla ice cream. Mmmhhmmmmm...delicious. :D
Actually we had couple board failures with DFI.. also lost one good CPU because in case of mosfet explosion :(
Few questions though. Why were you using ES chip for this OC attempt? Was this chip newer than retail available now?
Any leak how RB-C3 respond to cold Macci?
Most important: is AMD planning similar events in the future. Will they be hosted on other continents as well?
It's amazing to see 6.5GHz on a monolithic 750+ million transistors chip. You should make an entry to Guinness book with that :D
