http://i251.photobucket.com/albums/g...y1/Capture.jpg
Too biased towards quads.
I don't know where get this too biased towwards quads or why you think it hog resources.
but looking form what is showing 6.8 is really high for a dual, though put is good to 19,000 running in dual channel vs single channel must affect it.
my quad phenom at stock is hitting 15ms and about 17,000 kuc. OC to 3.0ghz 10ms and 26,000kuc
Heres Mine E8600 @ 5250Mhz
Just warming up :D
I shall break 80k with the i965 with the ThermalRight Ultra-120 Extreme and tightened RAM timings ( let's say DDR3-1800 6-5-5-16 :D )
http://i40.tinypic.com/r94l5d.jpg
i7 920@4.2ghz 6gb OCZ @ 1603mhz 8-8-8-24-1t Vista 64
dude, run the other one, the forced 32 bit version I believe, get much higher scores
Here is mine at 4.2 GHz
http://forums.techpowerup.com/showpo...&postcount=374
better run, best till date
http://img.techpowerup.org/081225/Capture003.jpg
and a better run...
http://img.techpowerup.org/081225/Capture004.jpg
NICe run CP. this by far the best bench ever made. now we need anand and tom's to use :D
hi everybody, this is my first post and what a great forum this is
my score with q6600 2,4ghz @ 3,850ghz max clock, 1,69v Vcore (i know its a very high Vcore...on air btw)
http://bildr.no/thumb/311758.jpeg
^^^^welcome gjeewaytee
nice run!!
here is a run with my Phenom 9950 @ 3.2 GHz
http://forums.techpowerup.com/showpo...&postcount=221
we need some phenom II's now
Basic E8400@3600 and DDR2-800 4-4-4-12 setup
Here is my "Particle Score"
http://img161.imageshack.us/img161/378/65676803bp2.jpg
Is it odd that my score is better than Hennels E8500@4123?
techpower has a huge Page of this I mean really huge, it's sad this doesn't have a bigger one :/ this XS where is started lol
Phenom II 940BE @ 3.8Ghz / DDR2-1066 5-5-5-15 2T / Win7 Beta 64-bit
http://i91.photobucket.com/albums/k2...5-55742-Be.png
http://i91.photobucket.com/albums/k2...5-61501-Be.png
not bad, nice crunch time.
My highest are below, both AMD and i7. I dont think I did to bad with my 9950 compared to the Denebs :D
9950 @ 3412 MHz
Crunch - 8.894 Throughput - 29474
i7 Hyper Threading on @ 4192 MHz
Crunch - 6040 Throughput - 86803
Q6600 @ 4102MHz - 2GB DDR2-1139MHz @ 4,5,5,18,2t
Phenom X4 9950 BE @ 3.2GHz - NB 2,4GHz - HT Link 2.2GHz - RAM 2GB 1066MHz 5-5-5-15 Unganged
http://i270.photobucket.com/albums/j...PUbench30k.jpg
aah .. now .. huh? the deneb is only 200mhz slower but the results are quiet different. worse. you guys sure you used the same version?
whats the deal here?
demon use the other version the x86 or what not. Scores will be a lot higher!
