Originally posted by SoulEdge
Anyone know how to disable APIC (no ACPI) in the bios? I couldn't find it anywhere. I'm trying to fix my audigy crackling and when I changed the pc driver to "standard pc" it will hard lock as soon as it boots into windows now. I'm wondering if there's something I overlooked in the bios or if I'll just need to reformat and specify which config to load when I install windows...
I think you can disable APIC when you disable Hypertrading in the BIOS. Correct me if I'm wrong.
