Awesome, thanks alot Malik. Ive been waiting for some results myself.
anyone with results yet ? :(
http://www.abload.de/img/dscf0932p53w.jpg
Today i show results ;)
I have one coming in the next week or so from NCIX.com for the ol' Q9550 system. I wish they had a mounting mechanism for Socket LGA 1366. I would definitely use it over my Swiftech Apogee GTZ.
They do:
http://www.ncixus.com/products/35581...1366/EnzoTech/
Comes with a backplate also. Only issue is, make sure you install your chip first, then the adapter, it blocks the socket lever that holds the chip down, so once installed you can not remove the chip.
Wow... thanks...:)
I glanced over at NCIX when I bought the Luna and didn't see it.
http://www.abload.de/img/dscf0947cv6p.jpg
Test in progress ... for this moment:
- luna has better temp in idle than gtz - 1,2 degress
- other important thing: Swifty is more flowkiller:
RPM of MCP 355:
- GTZ: 4055
- Luna: 4355
If those results are consistent, then it is really impressive. Any results with the system under load?
bitspower is always a sexy work of art, the p0rn of the computer world.
You just sold me on that and as for the Bitspower fittings.. I'm going to test some out.
http://img.photobucket.com/albums/v5...L/purchase.png
http://www.abload.de/img/wykres_lunaodh8.jpg
Some info about test method:
- Program for reading temps: RealTemp 2.90 ( maximum temps was marked )
- Idle mode: 2h work with internet, winamp - Fans on 4V
- Stress mode: 10 loop on 3Dmark vantage with stock gpu -Fans on 12V
- Stock CPU mode: QX9650 3Ghz 1.18V
- OC CPU mode: QX9650 4.4Ghz 1.42V
And something about flow in RPM's ( higher result is better ) :
http://www.abload.de/img/flow6my0.jpg
Images are giving me trouble...
anyone else having same problem??
I was until I visited his gallery now I can see them.
Pretty much the Luna creams the GTZ. I currently am using a GTZ and had ordered a Luna to use it on my Q9550 build.
As you can see above I ordered the Socket 1366 adapter. Luna is going in my main rig. Hellz yeah.
I also just ordered the Enzotech SNBW to replace the stock water block on my EX-58 Extreme. I saw a user on here rig his up with an SNBW and it looked pretty sweet.
Never used an Enzotech product before but it appears they make great stuff.
Wow. another pretty block, it's so cool, but pls make a test!
Malik, can you repost those results in the forum under a seperate thread?
I think thats excellent that people may skip over.
I'm using this block right now but I don't know if the result is impressed..
For my setup:
Jingway DP-1200 Pump
1/2 hose (changed;))
Rad: BIX 360 w/ 3x 2k rpm 69CFM Fan
Q9550 @1.2v
IBT full load @ 50C. Ambient 17.5C
(not really a review but just for reference only)
Wow. What about Fusion v2 vs Luna ?
malik
what back plate were you using?
how tight did you mount the waterblocks?
what paste were you using?
what paste application method did you use?
how many mounts did you do on the waterblocks?
my opinion is that the swiftech mounting isn't good, i have to say it, even martin had problems with it, i tested it too and it caused me problems too.
I can't put my finger on it but, something just doesn't seem right. I just tested one of my DDC3.2's for flow vs RPM and was completely unable to sway the RPM's (zero, zip, nada) by adding restriction (ball valve on my testing res). How you managed to achieve a 263 RPM difference is....well....:shrug:
