Well...I've been doing some bench runs. I have to say, this is completely non-repeatable tests and I cannot even compare the fluid to distilled, the order of the bench apps run and crashes and everything else cannot be exactly reproduced for comparison. I won't put out numbers like that...its completely against my test methodology.
Attached is a pic of the test loop. Loop order is as follows.
Rad Oulet -> CPU Block -> Res -> Pump -> Rad Inlet
I do not have water temp sensors or a flow meter presently...flow meter should be here Monday. All of my settings and equipment were on the header of each graph, but temp sensors are on each rad fan for intake and exhaust of the rad fans. I will be able to give you exact flow numbers once I get the flow meter on Monday.
