Nothing here. Wil take fan off for a while next run to see if it does sweat without one.
i am specifically asking about "sweating" issues and whether kneaded eraser is any different to bluetac in that respect
I have one question
At what place can I get neoprene?
myself gonna do it just like the cpu area and hope for the best:D
just hope got enough eraser stuff
Some more pics :D
http://img.photobucket.com/albums/v2...P/IMG_5173.jpg
http://img.photobucket.com/albums/v2...P/IMG_5178.jpg
http://img.photobucket.com/albums/v2...P/IMG_5195.jpg
http://img.photobucket.com/albums/v2...P/IMG_5200.jpg
http://img.photobucket.com/albums/v2...P/IMG_5211.jpg
http://img.photobucket.com/albums/v2...P/IMG_5218.jpg
http://img.photobucket.com/albums/v2...P/IMG_5223.jpg
good luck with your bench
i plan to do the same soon
Thanks mate im looking forward to your results already. Now all i need is time to do the actual benching :D
do you have anything between kneaded eraser and that black insulation???
like a layer of paper or anything?
Between the insulation for F1 and the eraser i always put thin layer of neoprene so the eraser doenst stick to the tube's insulation.
http://img.photobucket.com/albums/v2...P/IMG_5238.jpg
i am asking if you put anything between neoprene and eraser
Me bad. Nothing between it.
bluetac sweats like a pig and solarfall was saying he uses a layer of something
i just asked to see what you guys do
i will do the same and see what happens
thing is i use fans all over the place here too
eraser is MUCH better than bluetac
just used it tonight :up:
@loc.o
If you had a NB pot handy you might want to slap that on there. at least with my quad on air nb volts really helped and that bugger got hot-- the reason why i bought a pot for her.
