http://www.lavalys.com/beta/everestu...yt3slknc9x.zip
Build 1597 - Stable :)
Thanx,for update
I'll have to check this out, out
the last one is very good version
Keep the updates flowing guys, many thanks.
No problem Richard,
Everest Ultimate Edition 4.60.1599
Scheduled to release EVEREST v5.00 in mid-January 2009,it will be fully optimized to Nehalem family processors.
Everest Ultimate Edition 4.60.1601
Merry Christmas !!!:toast:
thanks stasio for all updates :D
Merry Christmas :D
Awesome thanks stasio :up:
I have just purchased the license to this program and do you need to download the new versions as they are released then enter in your license key everytime? Or is there some kind of autoupdate feature?
Kill a wat (and Don Dan)
Simply download the newest beta, launch Everest, Enter in your valid serial key. From then on, all you have to do is simply extract any newer beta/final build to the folder you already have Everest on your HD/usb/flash. There is NO NEED WHAT SO EVER to enter in your serial every single time.
Yes,just replace files.Your setting and licence will remain same.:yepp:
Thanks for the heads up fellas :up: I'll make sure to do that for the next update
all builds after 1588 up 1601 take a crap load longer to start and they don't add any extra sensors.
I have latest Everest and all PSU voltages are measured wrong.
Any ideas or solutions??
Go to http://www.lavalys.com/forum
Create an account and then create a thread with your problem.
Should have a response within a day or two.
No slowdowns for me neither.
Thank's for update:up:
Cheers guys, please keep the updates coming!
i don't understand... why do they have to put random characters in the name and block the ability to directly view the download server to see what files are there? The betas are apparently no big secret, as they are posted quite often. But why make it so complicated to keep up with the latest version?
