Hi I have had overheating issues as well. I played a game for 30 min and had to let it cool down. The whole card generates heat. My solution was to buy 2 PCI blowers, 1 for each side of the 4870 x2 card as the full card overheats on both sides. I got mine from http://www.maplin.co.uk/Module.aspx?ModuleNo=31253 for £12. Also setting the fan to 40%. Blowing all the hot air around the card out the back of the computer. And is as quit as can be. Also important is the have a good airflow through your case. I have a temp gage and the inside of my case is normally only 1 or 2 degrease hotter than room temp. ATI have pushed this card to its limits in order to put Nvidia i it's place. This is an epic card and I could not be any more happy with it.
ASUS M3M32-MVP Deluxe
Bios 1406
AMD Phenom 9850 BE at 2600
Zalman CNPS9700-NT CPU cooler
OCZ Reaper HPC PC8500 OCZ2RPR10664GK at 1066 mhz 8GB 4x2GB
Sapphire ATI HD4870 X2
2 x PCI blowers around my GPU for Extra cooling
X-FI Gamer
Corsair TX650
2x Wertern Digital Cavir blue 640gb Raid 0
ASUS DRW-20B1ST
Thermaltake ArmorJr Case
With 4 Antec case Fans
3D Mark Vantage 12289
Why is this at the top of the news section?
