Muah,so what now,has it "CPU References" right now or does it come later?
finally , today i test my EP45T Extreme :)
First test with my Q9550 (WR) just on Aircooling !!!
For the moment , i test with the bios origin (F2) , i wait the news bios béta without the vdroop enormous with the Quad Core !!!
Impressive Fsb on air , it's better with my Biostar TP45 HP (521mhz on air) , maybe broke 560x8.5 under caskade or LN2 :rolleyes:
http://img111.imageshack.us/img111/7382/531mhzrv7.jpg
http://img118.imageshack.us/img118/6858/526x85bj8.jpg
I have too the Screen a 536/537x8.5 but the database of Cpuz is Out today :)
Nice one with a quad :)
What are your settings and have you "CPU References" in the bios?
Can you make a screen?
CPU Reference does not exist in the current BIOS.
Why are you so desperate about that minor setting?
CPU Reference helps a lot to get my quad over 475FSB primestable.
Its like GTLs on DFI Boards.
The P45-DQ6 and Extreme DDR2 Version has it,why not this one?
Spread the word:
F3c
http://www.fileshost.com/en/file/54691/ep45tex-f3c.html
Thanks m8.
Thank T-M
i received my first E86 today normaly :) but i need test my Q9550 too !! :D
My Valid with the Bios F2 on aircooling at 1.5/1.52v :
http://valid.x86-secret.com/cache/screenshot/397901.png
http://valid.x86-secret.com/show_oc.php?id=397901
just got this BIOS too. Will test it tomorrow
I can get over 600 stable with f3b, but i hope F3c can get the RAM dividers working!
Gigabyte BIOS engineer didnt realise we didnt have this BIOS yet, so i told em to start spreading it
Thanks Tim. If I get a chance will try it with my E84.
Thanks for the BIOS, will try it with the E8400 in a second. Do the memory dividers work? Sick of running the 1:1 divider :(
Yes, the memory divider works fine, but some of them can't work properly. I can get 900 Mhz (DDR3-1800) with 1:2 dividers and stable, more than that it gives me blue screen :confused: and i can't change the Command Rate. Runs 2T even if you change it 1T in BIOS. Will post the screenshot and FSB achievement soon.
K, command rate never worked so far and I've had DDR3-1800 7-6-5-18-2T working once for about 30 minutes before I screwed up a setting in F3B. Hopefully with another BIOS revision or two we'll have DDR3-2000 working with command rate. Need to finish writing a review before I can play with the new BIOS :down:
Presumably you guys are getting those RAM clocks on quads?
Try running a dual and anything other than 2.00D, thats where my major problems are.
No.. i'm running it with dual core E8400. Below a screenshot...
http://img216.imageshack.us/img216/3...765152tqt6.jpg
http://valid.x86-secret.com/show_oc.php?id=398783
someone else tried F3C and 3:4 ? I tested all and i find that is best one for high ram clock > 600mhz fsb.
I try it and i'm stuck at 600mhz fsb :confused: http://valid.x86-secret.com/show_oc.php?id=398795 . Any special setting to reach 630+ mhz fsb Thomas ?
Another screenshot, shows memory dividers works fine :
http://img140.imageshack.us/img140/6896/34pi8mss5.png
http://img229.imageshack.us/img229/8769/35pi8mgv4.png
http://img525.imageshack.us/img525/8434/58pi8mkp9.png
Oh, only 500fsb.
Try higher?
Now another:
F3e
http://www.fileshost.com/en/file/54883/EP45TEX-F3E.html
