I'll give you an example. I ran 4.0Ghz @1.224 for 4 hours, did a little surfing afterwards, left the computer on all night and then rebooted, went into the BIOS to start bumping it up a little more and it said I had an overclocking failure. It's completely random like that.
My OCZ platinum is rated 1.8v and that's what I run it at. I loosened the timings from 7-7-7720 to 9-9-9-24 to see if I could get any higher than 4.3. Might be the tRD is too tight, what do you think? It is on auto.
Also no one mentioned if they thought that my vdrop/vdroop is too much.BIOS is set to 1.4, CPU says 1.36 in Windows and 1.328 under load. Doesn't that seem like an awful lot?
http://i244.photobucket.com/albums/g...epol/mem-1.jpg
