im going to drill and tap another hole on top of the res :up:
thanks guys :) my a set of my LEDS came in, i think you guys will like them :up:
Little res looks awesome mate! :up:
love the res Evil, looks trick!
and I did notice the 'rising sun' in each picture, but to me that looks cool,tho after what you said I gave it some thought and how about wrapping the case with the rising sun, so its a complete sun?? just another Idea, I really want to see the outside match the 'WOW!' factor of the inside... and maybe, and this is a MAYBE, like the sun you use in your pictures, have it missing lil bits and pieces as if it was splattered with something that ate through it?? just a thought
Lookin good as usual evil :up:
Hey guys, small update
got my one of my leds in, check it out :up:
http://evil98.insanity-asylum.com/co...dnight/112.jpg
http://evil98.insanity-asylum.com/co...dnight/113.jpg
http://evil98.insanity-asylum.com/co...dnight/114.jpg
http://evil98.insanity-asylum.com/co...dnight/115.jpg
http://evil98.insanity-asylum.com/co...dnight/116.jpg
im still working on the case idea, so most
all are up in the air. well see when i get around
to that part. for now interior is a priority
im going to pic up paint today, my feser
tube comes in on monday, hopefully well have
the interior painted and done by then so i can focus
on the front and the case body
cheers
Lookin' good Bro. :up:
I'm digging those ribbon led strips big time. My supplier sells them and I have always wondered about them. They appear to give off a nice amount of illumination - not too much, not too little. After seeing how you've implemented them, I'm a hafta get me some. :yepp:
Looking forward to the next update with the Feser tubing. :)
yea the strip LED is very convenient :up: 12vdc + 3M tape on the back
i should be getting my next set of LEDs on monday as well as the feser.
i might split up the strip so i can use it on multiple areas but the even
glow maybe too appealing for me to want to change it.
i bought my paint yesterday. weather isnt to good and i cant get time
in the booth anymore.. (car crash season?) so im going to build a small
cardboard box booth :up: lol no i just need a clean place to spray
hey guys, got a the rest of my LEDs today and
my feser tubing should be at my shop when i get
home. hopefully i get to painting today. i need to
find my rivet gun first. im not sure if i should
un rivet it or not. i need to do some more fabricating
before dismantling the case thats for sure.
but tomorrows update should be some what exciting
to some. but untill then thanks for stopping bye
cheers
Looking good evil. :up:
i like what you did with that res evil, looks great, cant wait to see you finish this one
man, i wish i had the money and skills you have
btw the dominator airflow thing came of perfectly without leaving any residue, thx bra
glad the dominator came out fine
i got alot to update, but havent had time to take pics
ill be sure to get one in this weekend
but for now more conceptualizing :up:
http://evil98.insanity-asylum.com/co...dnight/117.jpg
:rolleyes:
Evil I would like to see what Statts has suggested, just so we have something to compare against, which will maybe lead to more ideas.... :up:
ohhh and please tell me your gonna wrap the entire case with the rays.... :rolleyes:
ohhh wait!!!
What if you had the sun in a corner which wrapped around onto the side and continued up the side of the case!!! THAT WOULD LOOK AWSOME! :D
update:
havent updated in a while, not much progress been super busy
but progress is progress. not much to say, the case design is
still up in the air, my main goal right now is to finish the interior
which proves to be an issue untill i can get all the water cooling
parts in. i did receive the feser tubing and all my LEDs, just dont
have enough time in the day to get it all done at once. i spent a
few hours making that dual 45mm fan mount, did it twice, broke
the first one, this one came out alot better but im unhappy with
one of the big circle, my vice squeezed it too much and it warped
the shape so its a slight oval...
cheers
http://evil98.insanity-asylum.com/co...dnight/118.jpg
http://evil98.insanity-asylum.com/co...dnight/119.jpg
http://evil98.insanity-asylum.com/co...dnight/120.jpg
http://evil98.insanity-asylum.com/co...dnight/121.jpg
http://evil98.insanity-asylum.com/co...dnight/122.jpg
http://evil98.insanity-asylum.com/co...dnight/123.jpg
http://evil98.insanity-asylum.com/co...dnight/124.jpg
http://evil98.insanity-asylum.com/co...dnight/125.jpg
http://evil98.insanity-asylum.com/co...dnight/126.jpg
http://evil98.insanity-asylum.com/co...dnight/127.jpg
http://evil98.insanity-asylum.com/co...dnight/128.jpg
http://evil98.insanity-asylum.com/co...dnight/129.jpg
http://evil98.insanity-asylum.com/co...dnight/130.jpg
be careful of passive cooling those VRM modules on that video card, mine would overheat and shutdown.
update of all updates!
Gimmee lol.
Tell us how it performs ok.
Nice evil, let us know how it goes!
Torment us with pictures of a BOX ....................... check
Torture us with evil waiting tactics....................... check
Make us suffer by not posting any more pictures..... check
Tease us with mATX crossfire.............................. check
-sigh-
Niiice :p And I agree to MomijiTMO about tormenting ;)
HERE a good OC review for your mobo!!
Good choice!!
awww man... i just bought another mcw60 without thinking.. i need single slot blocks for the 4870s or i can use my soundcard... ahhh
but the board is SEXY, ill post the picture tonight, i was just to busy yesterday.
edit:
also need the blocks to be single slot so i can still fit the fans inside.. if not i got some realy BIG modding ideas in mind to try and keep the things inside...
