Hello,:wave:
nice review over at hardocp. the final words point to some possible hard drive issues but in general the word is good :up:
http://enthusiast.hardocp.com/articl...50aHVzaWFzdA==
Hello,:wave:
Hehehe P5Q3 Dlx mate it's the DDR3 version... will have to give the E8500 a go then tomorrow to see if it's the same ordeal here...
And for BigJoe's SS mine can do it too :)
http://users.pandora.be/OAP/P5QDlx/P5QDlxSS.jpg
K Made some sort of Template (need to redo it slightly to add all the extra ram features)
JumperFree Configuration Settings
AI Overclock tuner: AUTO
CPU Ratio Setting: AUTO
FSB Strap to North Bridge: AUTO
FSB Frequency: AUTO
PCI-E Frequency: AUTO
DRAM Frequency: AUTO
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: AUTO
CAS# Latency:
RAS# to CAS# Delay:
RAS# Precharge:
RAS# Activate to Precharge:
TWR: AUTO
TRFC: AUTO
TWTR: AUTO
TRRD: AUTO
TRTP: AUTO
DRAM Read Training: AUTO
MEM. OC Charger: AUTO
AI Clock Twister: AUTO
AI Transaction Booster: AUTO
CPU Voltage: AUTO
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: AUTO
FSB Termination Voltage: AUTO
DRAM Voltage: AUTO
NB Voltage: AUTO
NB GTL Reference: AUTO
SBridge Voltage: AUTO
PCIE SATA Voltage: AUTO
Load Line Calibration: AUTO
CPU Spread Spectrum: Disabled
Advance CPU Settings
CPU Ratio Setting: Manual
CPU VID: Default
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Disabled
Vanderpool Technology: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
Grab it here : http://users.pandora.be/OAP/P5QDlx/P5Q%20Dlx.rtf
Nice Quad FSB, what about that perf level problem?
Any info on availabilty in the states. Now that I see 500FSB on 45nm quad my opinion is completely revearsed.
It's at newegg $209
More cheap than i expected...but later will be more cheap, and it's the first mobos, They are the first revisions yet, they can come with some bugs etc...
I'll wait a while..maximus 2 formula it's much expensive in the release..
In the beginning, the x38 and x48 seemed to be the best chipset, with best mobos. But those who had memories crucial and thought the x38 mobos its the best and bought the x38 did not do a good business, because the crucial announced the incompatibility of your memorys with x38 and x48. This is just one example of the problems that are likely to occur!
@R@ptor =]]
Sorry mate but you talk too mauch, so less talk, more read ;)
@Leeghoofd
Hahahaa very nice man :wave:
It's glad to se Yorkfield @ 500FSB :)
I am only commenting on what really can happen, just gave my opinion mate..
Sorry if you don't like
Waiting for more results on this wonderful mobo! :)
hi i'm Vietnamese . my P5Q-E
Ram Patriot PC8500
Water cooler
Nice clocks havu2000, thanks for posting and welcome to the forum :D
Is there any "Real" advantage ... in terms of OC'ing/Performance that P45 has over the P35?
I just got my ASUS P5K-E/Wifi-AP (p35) and i'm having some problems with it. I might end up RMA'ing it back to the 'egg ... and I'm considering getting this one. There's 4 versions of P5Q (P45) at ZipZoomFly ... varying costs ... not sure which one is better.
I'll be running Q9450 in it.
ok, i think this board dont like my Corsair Dominator PC2-8500 (cant boot 500FSB with 1:1 divider!).
now i tried with a 512MB PC2-6400 Ballistix stick and i can boot 520FSB with ~1.3v NB voltage...
http://valid.x86-secret.com/cache/screenshot/371529.png
http://valid.x86-secret.com/show_oc.php?id=371529
Glad you got it going somehow mate...and you are not the only one with issues with these sticks (on many more mobo's) Did you try TB disabled and setting power level yourself ? which Strap did you use ?
A screenie, I could prime my Qx9650@3600 with the P5K dlx with LLC enabled at 1.135 (Small FFT's), with the P5Q Dlx I can do it at 1.120 without LLC (1.2Vcore set in bios, drops to 1.17 in windows) So the new PWM design seems to be very worth it...
http://users.pandora.be/OAP/P5QDlx/P5Q3600.JPG
retail p5q deluxe comes with 0506 bios
this board is plagued with ram computability issues
so far..
team xtreem PC2-6400 Cl3s 4x1gb... 3 sticks work one stick no boot
crucial PC2-6400 2x2gb.. only can run in single channel..
both rams are working fine on LT X48's
tested, retested..
Oh man when does this end, using customers as beta testers :(
Look some problems showing.
that is what I was talking about.
And I also do not agree on the point, which is a crucial memories of low quality. The only problem was with the last batch of memories, with a quality that are horrible!
Soz but if 3 out of 4 sticks work and one doesn't think problem is more with that dimm then... for the Crucials no idea why....
I tried Mushkin PC8000 4gb kit and now working on Gskill PC8000 Kit at 1066Mhz 5-5-5-15 1.94volt... will try the Gskill PC8000 4-4-4-5 next week and see if 1200mhz is okay...
This board requires again a total different setup coming from P35 or X38 to get there...
And a new bios is in the making, I had some issues with 400FSB/1000mhz ram 0604 Alpha seemed to fixed it... :up:
Did some testing at 400FSB (425 and 450 will come later) to see how the performance levels are set by bios and how low manual it worked
400FSB and Ram at 800Mhz -- Bios sets 13 perf level at AUTO setting -- Lowest manual is 9 (8 doesn't post)
400FSB and Ram at 1003Mhz -- Bios sets 10 perf level at AUTO setting -- Lowest manual is 7
400FSB and Ram at 1066Mhz -- Bios sets 9 perf level at AUTO setting -- Lowest manual is 7
Here are the screenshots; CPU at 3200mhz, Ram at 5-5-5-15 (TRFC 55)
http://users.pandora.be/OAP/P5QDlx/400-800.JPG
http://users.pandora.be/OAP/P5QDlx/400-1003.JPG
http://users.pandora.be/OAP/P5QDlx/400-1066.JPG
Think we still need some more work there Asus engineers to get the board up to speed...
EDIT :
450FSB and Ram at 900Mhz -- Bios sets 13 perf level at AUTO setting -- Lowest manual is 10
450FSB and Ram at 1081Mhz -- Bios sets 10 perf level at AUTO setting -- Lowest manual is 8
screenies :
http://users.pandora.be/OAP/P5QDlx/450-900.JPG
http://users.pandora.be/OAP/P5QDlx/450-1081.JPG
Is there any difference in bios between P5Q-E and Dlx? Is it possible to flash dlx bios into P5Q-E?
thanks
Ordered P5Q-D today, should be here by Tuesday.
Leeghoofd, you hit a PL7 @ 1066MHz on a 400FSB with what RAM configuration, 4x1GB or 2x2GB, and what brand were you using?
I've got a whole mess of DDR2 to work with:
4x1GB Cellshock PC8500 D9GMH
4x1GB Mushkin PC8500 D9GMH
4x1GB Patriot PC8500 D9GKX
2x2GB OCZ FlexII PC9200 Powerchips
Which RAM does this board prefer, D9GMH, D9GKX, or powerchips?
I'd prefer to use 4x1GB since I can pull tighter timmings with 4 sticks over the 2x2 configuration and I'd like to use the Cellshocks since they seem to clock higher.
Is their a Beta BIOS available from their FTP site or is the 0506 the latest BIOS?
Thanks....
Edit
Will I need to do a format? I'm currently on my Maximus Formula x38 using the latest drivers from station drivers, 8.2.0.1001 which includes the ICH10.
