http://pix.nofrag.com/7/3/5/47ba8231...dfb58020tt.jpg
I found this in emergency :D
it was still with my Gigabyte X38T-DQ6
hy
great results he have here :clap:
i canīt get more that 570 on mine simply dont boot but at 550 is fully stable with 0401.
someone ask to the compatibility with the ocz gold 7-7-7, i have one of those and the max achieved was 1340mhz at 8-7-7-20 and more than that is no go wont boot :rolleyes:
with the gskill HZ is a complety different story and iīm very glad with the performence\price of them.
:up:
Yep jpcastro, I asked for that incompatibility issue and with the initial bios 0115(which i will keep for some time again), I don't meet any issue atm, Thank you to answer to that ;)
EDIT: Well !!!!!! I was wrong, the reason to my mistake is that i am only trying to get the max fsb at first, then no need to increase ram frequency... I'm f****d too :shrug:
@jpcastro... do you use Vista or XP (32bit) ??
check your inbox :up:
i use VISTA 32bits for daily use and another disk with XP 32bits for benches :)
very good ! :woot:
Is that the max you got? looks promising man :)
would I be jalous ?? :p:
:D Received my G.Skill 1600 GBHZ today:
http://img266.imageshack.us/img266/994/8x500eg6.th.jpg
1.94 Vdimm
1.36 Vtt
1.52 Vpll
1.45 Vnb
1.20 Vsb
0.80 Vcoc
Very stable 1T & tRFC 60 (!!!) - only 0.02 Vdimm more than the blue Cellshocks, but almost half the price..........;)
BTW - if You have the feeling somthing is a bit unstable or You have probs during boot -----------> lower the Vpll.
With 1.54 I had reboots sometimes, with 1.52 it's perfect stable.
:welcome:
vnb ~1.75
vpll 1.64
vfsb 1.48 - 1.46
overcharge auto
static and dynamic disabled
oki doki, that's very kind from you :) plus thats not bad. I did put 1,77 vnb to get my 591/~3 fsb, should try tolower it then.
I've been told that such a vnb could damage components(as for vpll on wolfies), but as long as we (want more) do not pretend to stabilise the system at such fsb frequency lol, 'should be allright yo!
Keep pushing man
Look.
I have water on vnb so its *cool* the 1.75v.
If you are on stock air its too much the 1.75.
Maybe with lower vnb you could go higher cause of temps ;)
And at 600mhz i m with single channel.With dual channel i stuck at 597 :p
Did someone found the vcore and vdimm measure points on this card ?
:D Here're some BIOS shots for You - running E8500 @ 8x500 & G.Skill 1600 GBHZ @ 1GHz:
http://img361.imageshack.us/img361/2...n001oj1.th.jpg
http://img361.imageshack.us/img361/9...n002vk5.th.jpg
http://img361.imageshack.us/img361/2...n003xe7.th.jpg
http://img361.imageshack.us/img361/3...n004bo8.th.jpg
http://img361.imageshack.us/img361/7...n005pj9.th.jpg
Remember voltage settings require a proper cooling - I'm running CPU & NB under chilled water and have a lot of airflow to the board:
http://img91.imageshack.us/img91/721...tionwu4.th.jpg
:welcome:
thank you Camou', ain't mothing like a picture ! ;)
uau thanks for the screens camouflage, i´m gonna test the HZ again to see if i also can have 1T stable.
another thing did you test a Spi32 for example? i had to rise de vdim to have stablility but also made DDR2000 with 1,94v 2T
:up:
0115 :p
