LP UT X48-T3RS, E8400, 480x8.5, ReaperX 1333MHz, Post 1 Of 3
E8400
DFI LP UT X48-T3RS, 06/09 BIOS
480x8.5, Memory 1600MHz
2x2GB OCZ PC3-10666 1333MHz ReaperX
XFX8800 GTS (G92)
tRD - 8.5, Memset Misreads The Value When Set Manually
Memory Speed - 1600MHZ, CPU-Z Misreports The Divider
Yellow Slots Used For Memory
click for larger image
http://www.edgeofstability.com/image...ios/main_s.jpg http://www.edgeofstability.com/image...ios/volt_s.jpg
http://www.edgeofstability.com/image...s/dram_1_s.jpg http://www.edgeofstability.com/image...s/dram_2_s.jpg
http://www.edgeofstability.com/image.../clock_1_s.jpg http://www.edgeofstability.com/image.../clock_2_s.jpg
http://www.edgeofstability.com/image...os/phase_s.jpg http://www.edgeofstability.com/image.../feature_s.jpg
Code:
CPU Feature Page
Thermal Management Control................Enabled
PPM (EIST) Mode...........................Disabled
Limit CPUID MaxVal........................Disabled
CIE Function..............................Disabled
Virtualization Technology.................Disabled
Core Multi-Processing.....................Enabled
Main BIOS Page
Exist Setup Shutdown......................Mode 2
Shutdown After AC Loss....................Disabled
O. C. Fail Retry Counter..................0
CLOCK VC0 Divider.........................Auto
CPU Clock Ratio...........................8.5x
CPU N/2 Ratio.............................Enabled
CPU Clock.................................480 MHz
Boot Up Clock.............................Auto
CPU Clock Amplitude.......................800mV
CPU Clock0 Skew...........................0ps
DRAM Speed................................400/1333
PCIE Clock................................100MHz
PCIE Slot Config..........................1X 1X
CPU Spread Spectrum.......................Disabled
PCIE Spread Spectrum......................Disabled
SATA Spread Spectrum......................Disabled
Voltage Setting Page
CPU VID Control...........................1.34375V
CPU VID Special Add Limit.................Enabled
CPU VID Special Add.......................Auto
DRAM Voltage Control......................1.837V
SB Core/CPU PLL Voltage...................1.510V
NB Core Voltage...........................1.543V
CPU VTT Voltage...........................1.144V
VCore Droop Control.......................Disabled
Clockgen Voltage Control..................3.45V
GTL+ Buffers Strength.....................Strong
Host Slew Rate............................Weak
GTL REF Voltage Control...................Disabled
CPU GTL 1/2 REF Volt......................113
CPU GTL 0/3 REF Volt......................100
North Bridge GTL REF Volt ................100
DRAM Timing Page
Enhance Data Transmitting.................Fast
Enhance Addressing........................Fast
T2 Dispatch...............................Disabled
Clock Setting Fine Delay..................Listed Below
CAS Latency Time (tCL)....................7
RAS# to CAS# Delay (tRCD).................6
RAS# Precharge (tRP)......................6
Precharge Delay (tRAS)....................20
All Precharge to Act......................Auto
REF to ACT Delay (tRFC)...................Auto
Performance Level.........................9
Read Delay Phase Adjust...................Listed Below
MCH ODT Latency...........................Auto
Write to PRE Delay (tWR)..................Auto
Rank Write to Read (tWTR).................Auto
ACT to ACT Delay (tRRD)...................Auto
Read to Write Delay (tRDWR)...............Auto
Ranks Write to Write (tWRWR)..............Auto
Ranks Read to Read (tRDRD)................Auto
Ranks Write to Read (tWRRD)...............Auto
Read CAS# Precharge (tRTP)................Auto
ALL PRE to Refresh........................Auto
Read Delay Phase Adjust Page
Channel 1 Phase 0 Pull-In.................Enabled
Channel 1 Phase 1 Pull-In.................Enabled
Channel 1 Phase 2 Pull-In.................Enabled
Channel 1 Phase 3 Pull-In.................Enabled
Channel 1 Phase 4 Pull-In.................Enabled
Channel 2 Phase 0 Pull-In.................Auto
Channel 2 Phase 1 Pull-In.................Auto
Channel 2 Phase 2 Pull-In.................Auto
Channel 2 Phase 3 Pull-In.................Auto
Channel 2 Phase 4 Pull-In.................Auto
Clock Setting Fine Delay Page
DRAM Default Skew Model...................Model 3
Fine Delay Step Degree....................5ps
Ch1 Clock Crossing Setting................Auto
DIMM 1 Clock fine delay...................Current 489ps
DIMM 2 Clock fine delay...................Current 489ps
DIMM 1 Control fine delay.................Current 434ps
DIMM 2 Control fine delay.................Current 473ps
Ch 1 Command fine delay...................Current 205ps
Ch2 Clock Crossing Setting................Auto
DIMM 3 Clock fine delay...................Current 686ps
DIMM 4 Clock fine delay...................Current 686ps
DIMM 3 Control fine delay.................Current 607ps
DIMM 4 Control fine delay.................Current 654ps
Ch 2 Command fine delay...................Current 182ps
Ch1Ch2 CommonClock Setting................Auto
Ch1 RDCAS GNT-Chip Delay..................Auto
Ch1 WRCAS GNT-Chip Delay..................Auto
Ch1 Command to CS Delay...................Auto
Ch2 RDCAS GNT-Chip Delay..................Auto
Ch2 WRCAS GNT-Chip Delay..................Auto
Ch2 Command to CS Delay...................Auto
Common CMD to CS Timing...................Auto
LP UT X48-T3RS, E8400, 480x8.5, ReaperX 1333MHz, Post 2 Of 3
LP UT X48-T3RS, E8400, 480x8.5, ReaperX 1333MHz, Post 3 Of 3
LP UT X48-T3RS, E8400, 500x8, Platinum EB 1600MHz, Post 1 Of 3
E8400
500x8, Memory 1666MHz
2x2GB OCZ PC3-12800 1600MHz Platinum EB
XFX8800 GTS (G92)
Memory Speed - 1666MHZ, CPU-Z Misreports The Divider
Code:
CPU Feature Page
Main BIOS Page
CPU Clock Ratio...........................8x
CPU N/2 Ratio.............................Disabled
CPU Clock.................................500 MHz
CPU VID Control...........................1.31255V
DRAM Voltage Control......................1.855V
NB Core Voltage...........................1.630V
CPU VTT Voltage...........................1.325V
Host Slew Rate............................Strong
DRAM Timing Page
Ch 1 Command fine delay...................Current 560ps
Ch 2 Command fine delay...................Current 639ps
Common CMD to CS Timing...................2N
http://www.edgeofstability.com/image...6_memset_s.jpg
LP UT X48-T3RS, E8400, 500x8, Platinum EB 1600MHz, Post 2 Of 3
LP UT X48-T3RS, E8400, 500x8, Platinum EB 1600MHz, Post 3 Of 3
