I never ended up getting the custom window done and this build has since been decommissioned
I had it running for a few months but I had a lot of issues with the layout.
What I learnt:
- Common res sux, I should have had two independant loops
- Difficult to tube up back to back rads. I was constantly getting issues with kinked tubes in te space between the rads, the floor of the case made it really difficult to get this sorted.
- 1 DDC was too weak for my CPU & chipset loop... I was running at about .6-.8 GPM
- Those U flowmeters from Koolance are crapola, restriction was one thing, but build quality was also bad with the threaded ends just glued in. Ended up leaking.
- Too many LEDs make your eyes bleed
- Single bay res was too small, and the location was bad for filling.
Ive since built my second WC rig, I ended up canabilising some of the parts from my TJ07.
Build log is here http://www.xtremesystems.org/Forums/...d.php?t=205938
