well the cooler is done but for the TESTING ! in real time on a PC
I have to do assy under the floor as it's larger assembled than not & my access to the crawl space just fits the steel box & not the whole unit
SOO the Next thing up was yesterday I buildt was W/C'd high end test bed
I need to test the whole thing outside the case soo i can build the pump/res box
>> Plus test the Rampage Formula/QX9770 out before ripping the stock cooling off to make sure that both are not DOA on me
i had got a HSPC tec bed but really was not happy about how small it was & was pissed I had ordered a MoBo on the bottom bed
anyway the bed will hold on a GTX360/EK150 res/ddc pump with a petra top all the time soo i can test MoBo's/do builds
i will be hooking up the dual Iwaki's & the dual EK 400's on the bottom deck for the Crawler coolerr test on this bed & do most of the tubing runs
here's the PIX of the test bed (up load failed on the pix seems the server is down )
DDC pump / resevoir & rad 360 will be Hard installed today I'll post pix on that when i'm done
