I've got an odd one for you guys.
Since doing the mods I can't run over 1.6 volts :shrug:
Any ideas why this would be ? (if it matters I'm under LN2 doing this)
I only tested the mods at around 1.4 volts and all seemed fine.
Before I did the mods I could hit 6Ghz @ 1.96 volts one core easy http://valid.x86-secret.com/show_oc.php?id=369183 but I had real issue being SPI stable over 5714Mhz (my cpu is good for 5.9) so a vdroop mod was in order.
@ Kabauterman, what were you issues under the cold ?
Edit:
Just tried around 0c, same issue.
Though you can see the vdroop mod is working.
http://img502.imageshack.us/img502/2...coreor9.th.png
