I'll give it a try, I've been meaning to try couple out on my old orange impeller DDC2, I have a black impeller DDC also, but it's got a burnt chip and about to go, but if it works on the orange, it should work on the black.
The problem I had on the top of the XSPC reservoir top was the thread depth on the reservoir wasn't deep enough so the black plastic cap threads could slip when tightend alot. I probably wouldn't have noticed in a normal system without a second reservoir, but since my testing rig included a much larger reservoir, that cap has to seal perfectly, or it'll try to leak a little on me.
I wouldn't worry to much about it in a normal system if your reservoir is mounted upright, but I wouldn't want to mount one sideways. I talked with XSPC about the threads, and my sample was previously used, so it's possibly I just got one that was partly damaged.:shrug:
