Originally Posted by
DilTech
I see you seem to be confused... I'm going to break this down as best as I possibly can.
All current multi-gpu setups, be it multiple cards, or multiple gpus on a single card, all need to have the same information in each gpu's memory banks, essentially dropping the ram down to one gpu's ram size available.
Crossfire and this card have similar performance because they are practically the same thing, there's just less latency in communications with the 3870x2 compared to twin 3870's, and as such it gives the 3870x2 a bit of an edge over twin 3870's.
Both of them suffer the same issue, even though there's 1 gb of ram total, seeing as both gpus have 512mb of ram, and both need to store identical info in their 512mb, it's the same as only having 512mb.
So, if you were thinking Cross-Fired 3870's effective doubled the ram, you were mistaken... See why they're so much alike now? :up:
