Shoggy, I like how you put all the cables out of view of the window. Not necessarily managed, but just good looking.
putting in a request here.
can anyone remember who posted the PC-343B with the phase unit coming from over the other side, and had watercooling on the remaining components?
or if not, anyone saved them maybe and can post them??
Some pictures of mine V1000b Plus II.
http://i40.tinypic.com/eh0img.png
http://i44.tinypic.com/s3it14.png
More pictures in buildlog
http://www.xtremesystems.org/forums/...05#post4392605
Wow! Some very creative angles on such a beautiful build! ^
Here's my X1000 build :)
http://img704.imageshack.us/img704/3042/70093242.jpg
http://img824.imageshack.us/img824/4899/51824787.jpg
http://img23.imageshack.us/img23/2920/86733914.jpg
http://img130.imageshack.us/img130/5548/75602211.jpg
http://img203.imageshack.us/img203/1703/64353152.jpg
http://img805.imageshack.us/img805/9080/99333607.jpg
http://img535.imageshack.us/img535/4649/68887465.jpg
http://img20.imageshack.us/img20/5751/90275878.jpg
http://img692.imageshack.us/img692/1425/84062402.jpg
wow! very nice converge! love it!
very nice converge :)
Wow, I always thought the PC-X1000 was massive, but it actually looks manageable in that picture. Liking them more and more.
Thats some awesome work, but is a dual rad enough, or is there one more which cant be seen in the pics?
Yeah it's actually a very nice size, there's no wasted room in mine, everything fits very snug. Coming from a TJ07 the x1000 is a much smaller case.
Thanks man. Well it's actually a 280 (140.2) rad which is about equivelant to a 360. It is more than enough for my cpu and chipset loop and having 140mm fans makes it all very quiet.
Koolance's rads kind of mimic HWLabs ones (they have similar to GTS thin 30mm rads with 30FPI and full thickness 20FPI like GTX), IIRC they lack silent fan rads though in their line (like SR1).
The core on the Koolance rads is the exact same core on the GTS. The only thing different about them is the end tanks. If your looking for a quiet cooling solution, better look elsewhere for your rad. . .I suggest Swiftech MCR.
A little background:
Last year, I had to construct a new PC. Weighing cost, performance and price, I settled on a i7 920 2.66ghz + GTX295 video card.
The graphic card had a fan/heatsink setup that ramped up during extensive usage and it sounded like a vacuum cleaner even though it was 2 meters away. The temps were high, 55c on idle and 91c on load. The noise got to me eventually. I needed a system to be fast and quiet (like a mac :D). I started research on water cooling a year back in Sept09.
With great advice from folks at OCF, RRTech & XS (esp Conumdrum, Spawn & Red), I took the plunge in April this year. Got MCR320 Drives that's a 3 in 1 system that included pump, radiator and reservoir. It was a simple setup for a newbie.
My current Lian Li case is way too small for the wc stuff. :p It's a bit of a Frankenstein setup but it's good for testing and learning. I will be looking into making a custom case in about 6 months.
Current temperature for CPU on load is on low 60s (10c difference from air cooling). GPU is running at 40c idle (~20c difference). I haven't had to the chance to test it on BFBC2.
It looks hideous but this system is way quieter than the old one. :D
Details:
Watercool.de HK 1366 water block (this waterblock doesn't take kindly to 1/2 compressions, even the 45 all in one rotaries. Found out too late an used a barb on the inlet)
EK GTX295 Single PCB water block
MCR320 Drive
1/2id 3/4od Primochill tubes
Mix of Bitspower compressions and barbs
the last project in lian li v1000 plus black
Hardware spec
Intel i7 920 D0
Gigabyte x58 extreme
Nvidia gtx 285
Crucial d9kpt 2x3g
Enermax liberty 620 w
Seagate 160gb+WDC 640gb
Liquid cooling
WB CPU : Heatkiller 3.0 LT
WB GPU : Koolance VID-NX285
WB RAM : Koolance RAM-33
Pump : Swiftech MCP655+koolance COV-RP450
Fitting : Koolance Nozzle Pair, Compression ID:1/2 OD:5/8 + ID:3/8 OD:1/2
Tub : Masterkleer ID:7/16-OD:5/8 + Tygon 3603 ID:3/8-OD:1/2
RAD : XSPC RX 240+ XSPC RX 120
RES : handmade
FAN : lian li standard @ 1500 rpm + scythes slip stream fans 1200rpm
http://image.ohozaa.com/i4/2khb1.jpg http://image.ohozaa.com/iy/7tie6.jpg http://image.ohozaa.com/ir/4vg05.jpg http://image.ohozaa.com/ip/0da154.jpg http://image.ohozaa.com/i6/jave3.jpg http://image.ohozaa.com/i9/vmj72.jpg http://image.ohozaa.com/io/zgwp7.jpg
^ Your memory cooling tubing is very uniform! Like it !
I should add mine too! This is mkII after my 775 died, upgraded to i7 and made a few improvements. Pretty similar layout to tipgo's except my rad is along the top.
http://masseys.id.au/pics/zp-core/fu...00953.jpg&q=75
http://masseys.id.au/pics/index.php?...e=DSC01018.JPG
(wow, need to resize that image!)
