copy the msconfig.exe from the winxp system to the win2k rig
Fine. :D
I try that when I get home. Maybe it brings me to new hights though I doubt it ;)
Here's some 'ln2 improved' results:
1M => 30sec (@4801MHz)
8M => 5min 34sec (@4801MHz)
I had a run at 4868 which gave 29sec but it seems that I've replaced that screenshot with the 8m one (once I started lookin at the screenshots I noticed I had two of those 8m shots and only one 1m) :/
Man macci were tied @ 30sec 1mb and you had -200+degrees and 100 mhz on me wtf:)
well I'm using slow bios and also you know how much extra CPU it takes to cut even 1sec off of the time :)
Wooooohoooo. Macci, for 30sec it would need a 3200MHz barton at least :D
how about 29sec! :D
http://www.solidhardware.com/macci/32c/4925_spi_1m.gif
managed to pull that off with the last drops of ln2 I had :)
Originally posted by macci
how about 29sec! :D
Hi Macci,
Nice bench:toast:
thats hard to beat...
AGP/PCI not lockt? can you tell why, can that be done with ATI:rolleyes:
that bench is with R9800 on AGP slot :)
APG/PCI is locked at 72/36 on that one. When past 300FSB the AGP/PCI needs to be set above 66/33.
thats incredible, TAM has the world record right? 28 seconds or so?
Yup TAM has the top spot with 28secs @5040MHz.
the 1M ranking can be found here
Looks like Macci's close to matching or breaking that real soon. :frag:Quote:
this brings up the inevitable macci, can you hit 28 seconds?
:slobber:
With Vcore and Droop voltage mod I might have a chance of running the CPU at over 5GHz SuperPi stable but in order to hit 28sec I should be able to run the mobo and RAM at 315FSB 5:4. I've run it thru 3dmark at 313 5:4 so that might be possible too. Its just that I need to use BIOS 1008 (which is not very fast) to reach that speed. Not sure if TAM used the same bios when he hit 28sec.
So if he did it with 1008bios then yes I might stand a small chance of hitting it but if he did it with 1002 or pretty much any other bios then its out of the question :)
Ah man of course you can do it youre macci for the love of god:)
Now come to chat sir:)
Uh Oh! With two super OC'ers (DJ and Macci)working together on this anything could happen. :idea::idea:Quote:
Hmm, do i dare to post my result here:) 35sec
2.6C L321 @ 310x13 cooled by MII (Max3 MB)
another bench, with more vddr :D
it's with my old XMS 3500
3.68v SC
http://membres.lycos.fr/ftpad/images...3-2226-39s.png
3.50v DC
http://membres.lycos.fr/ftpad/images...DC259-2225.png
Running it with runprio.exe (makes it run in true 'real time mode') might just cut that one second off of it ;)
33sec at 2560MHz
I get 38 seconds at 3.6 Ghz
the 5 Ghz stuff from macci was incredible:slobber:
36s@3.7GHz
36s@3.686GHz too
I think I can get 32s@4GHz (333*12 asynch in 5:4)
http://membres.lycos.fr/cpulloverclock79/1m.JPG
40 sec , 11.5 x 220 xp2600+ ( old bench ) Pic
P4 3200@4300
http://pprocha1.no.sapo.pt/SuperPI_32sec.jpg
is prommy cooled?
My 1M is 44seconds. Screeny capture not working ATM.
