Man, THAT is one SWEET brick. 220W is just colossal for a power brick...
I can't imagine how much noise that thing produces, though... Is 120W bricks are noisy, that must sound like a jet plane taking off... hehehe
Thank you for the compliment.
Well, first I'll need to figure out exactly how much power does the Mobo+CPU+Memory combo draw on each of the lines.
Then, I'll actually need to know how much power do the WD drives draw on spin-up, to make sure I won't cross any boundaries just by powering up the drives (it CAN happen... remember we're talking VERY low numbers here...)
The first one I cannot know for sure. You can help there, though... It seems it's possible to measure how much power is being needed through the connectors (not sure how, last time I took physics was like 10 years ago...):
Probably, sticking a multimeter in there and just measuring how much AMPs are being sucked can also work... hehehe Just be sure to measure both motherboard connectors, since the 4(8) pin one is a different rail from the 20(24) pin.Quote:
Originally Posted by The Tech Report
So, if you can help out there, we'll see just how much power your motherboard actually needs. Do be sure to measure at full load, though, else it may botch the results.
I do have, however, a figure for spin-up for the 1TB drives (I'll assume it's the same for the 500GB, I shouldn't be too off), courtesy of STRC (StorageReview.com): 1.36A+0.96A (12V+5V) EACH.
Also, I'll have to take a look at the M4's manual for the power ratings. They're actually VERY good. 12A on the 12V rail (if you're inputting 11-16V to the PSU), 15A(!) on the 5V line.
The M4 is rather new. A couple of months old at best, probably. I didn't find anything on it yet, not even on efficiency values. But perhaps I didn't search enough...
Also, do keep in mind that, with your current setup, and if my last calculations were correct, at peak consumption you'll already be on the danger zone for the Pico120, which is a 140W max PSU, will ALL the rails accounted for (I don't think it would last long with full ~200W - peak - load on all rails, really...). So, you'll surely be at 50%+ capacity with the M4...
So, let's do some maths, ok?
So, I'll need to make sure the Mobo+CPU+Memory+(n-1) drives powered up and idling keep below (12A-0.35), so the last powering-up drive (due to staggered spin-up, remember? All the other will be powered up by then) doesn't overload the PSU too much AND normal operation falls within the PSU specs. Actually, that math is wrong because those are worst-case values, but it's best to work with full power figures, just in case...
So, "Start->Run->Calc", and you get:
12V line (12A available, peak at 16A for sub-30'' periods)
4A for the Mobo+CPU+Memory (pending)
1.5A max for the controller
3.28A for the 1+9 drives
1.36 for the last powering up drive
Total of 10.14A peak when starting up the HDDs (actually, that should be more like 8~9A, because of that "worst case scenario" I was considering.
5V line (15A available, peak at 20A for sub-30'' periods)
3A for the Mobo+CPU+Memory
6.87A for the 1+9 drives
0.96A for the last powering up drive
Total of 10.83A peak when starting up the HDDs (again, that should be lower, probably on the 8A range).
After all this, we also have to consider three other things:
1) Power draw on the +3.3 and +5VSB lines (not usually much, but better make sure, because of what I'm going to say next);
2) Max output of the 220W brick, which is 18A@12V, meaning only ~3A(@12V, which isn't actually all that bad) will be available for other lines in this worst-case scenario, so you'll have to do OTHER maths for those lines;
3) Power efficiencies - I'm not taking those into account, especially the power brick efficiency limitation, so you might need to check on that, ok?
In short, if I didn't mess anything up you should be able to run that server off an M4, plus a 200W+ brick.
Hope this helps.
Cheers.
Miguel
