Originally Posted by
Don_Dan
I see you're lowering tRTC, tRP and tRC with Memset, that's one of the things I would have given you as an advice. Are you booting at 400 MHz FSB? If yes, then try to boot at lower FSB speeds and clockgen to 400MHz. That's because the strap change at 400MHz will not take effect if you pass this mark in Windows and it will keep on running on the faster 333MHz strap.
On 680i it's all about picking the correct divider, the best are 2:3 and 9:11 and maybe 9:10.
Look at my screen, that was the best result I've ever made on 680i, because my CPU doesn't like more than 400MHz FSB... :(
Only 600MHz on the RAM, but almost 11k in Everest's read test, all my changes in Memset and the used voltages are visible, maybe my tips will help you a bit. :)
