Could someone please mod my bios to 1.33V :)
big thx in adv
big thx in adv
Done! Took me only 5 minutes to edit it.. wow, it's easy once you understand the hex editing and the tables. The checksums are identical but you'll have to use Rivatuner for overclocking. Here it is with the description:
Description:
HIS GeCube 3850 X-Turbo III 512MB 725/900 default clocks
MODDED BIOS WITH 3870 voltage (2-D: 1.241v, 3-D: 1.327v)
Flashing guide: http://www.iax-tech.com/howto/atiflash/01.htm
click on "I Agree" to view content (no need to use "-f" to force flash.. better to not use it).
I'm too lazy to be honest ;)
big thx
Strange.. my card was running Bioshock, The Witcher, CoD4, etc.. at 800 MHz all day long yesterday when my brother was indulging in those new games during his Xmas visit. Are you able to run any games at 800Mhz? The other guy 'motox' recently posted here that he could do Crysis at 810 MHz with my modded HIS bios. I'm sure that I can do all of those games at 810 MHz but since Quake3 crashed at 820 MHz, I chose to back down to 800 Mhz just to be safe, which is already within 2% of known limit for stability.
Also, what was your previous max OC with your default bios? How much did my bios help your OC?
thanks a million for your help! :clap:
But it seems that overclocking doesn't work anymore (tried with rivatuner and CCC ... clocks can not be applied))
I don't know whats wrong :shrug:
That's a first that oc'ing wont work with RT. Was CCC overclocking already unlocked before you upgraded the bios? Just asking because I know that mine was already unlocked and RT still worked. It gave me 1100 extra points in 3Dmark03 and 150 in 3dmark06. How about trying AtiTool to see if it works?
If nothing works, maybe a reinstall of the drivers would do it? Or upping the clocks in your BIOS but that would be a big pain in the neck to find the OC limits that way.
ATi Tool works... thanks! :)
Oh, great! How much can you oc with ATiTool? Don't forget to verify the overclock in Rivatuner monitoring! Just in case it still didnt work I did another bios edit but this time the idle voltages are the same as 3850's default. Only the 3D load voltages are at 1.327v, equal to 3870's. Maybe it would work with CCC and/or Rivatuner overclocking.
Description:
MODDED BIOS WITH 3870 LOAD voltage (2-D: 1.014v, 3-D: 1.327v)
think mine just sux cant go any higher with more volts 750 max :( ty though
669MHz/829MHz/1.33V/boot
$0a00030100 Performance level 1 : 669MHz/829MHz/1.33V
$0a00030200 Performance level 2 : 669MHz/829MHz/1.33V
$0a00030001 PowerPlay state 1 : 725MHz/900MHz/1.24V/Overdrive
$0a00030101 Performance level 1 : 725MHz/900MHz/1.24V
$0a00030201 Performance level 2 : 725MHz/900MHz/1.33V
$0a00030002 PowerPlay state 2 : 725MHz/900MHz/1.33V
$0a00030102 Performance level 1 : 725MHz/900MHz/1.33V
$0a00030202 Performance level 2 : 725MHz/900MHz/1.33V
$0a00030003 PowerPlay state 3 : 725MHz/900MHz/1.33V/UVD
$0a00030103 Performance level 1 : 725MHz/900MHz/1.33V
$0a00030203 Performance level 2 : 725MHz/900MHz/1.33V
Those 1.24 are fine? or are they suppose to be 1.33?
Yeah, it should be fine since your default bios shows 1.01v in Rivatuner. Do you want me to change that to 1.33v also?
if u can ... :P Prolly wont help but worth a shot??
Did u use my original.bin file to mod or the other guys gecube bios? Cause i flashed back to my original bios as 750 is not even stable now... O_o
when I tried to flash my 3850 bios with winflash everything just freezed, after reset card was fine with the old bios, why ?
Hey OS, I executed the HexCmp, and for some reason on first run it did a NETSH command. That's uh, scary. It was too fast for me to see what it did, but do you have any clue as to why it would do that?
EDIT: SON OF A BLKSFDLKJWE:LKRJWL:KJ. There is a VIRUS in that file! Dude, seriously, I'm an idiot for trusting anything posted up here, but seriously.... WTF? ?!!?
This time, I made sure it's from your ORIGINAL GeCube bios, with everything set at 1.33v--even in low-power mode it will be running at full voltage, so your card will be warm all the time. Make sure to set the fan speed to 60% or higher in Rivatuner.
Here's the BIOS with 3870 voltage all the way.
Description:
MODDED BIOS WITH 3870 LOAD voltage (2-D: 1.327v, 3-D: 1.327v)
It's a mass mailer infected .exe. Look for pmxgl32.dll; It will now be in your shell init if you installed the program. It will also created a couple random named .dlls in your system32 directory. They will probably have a create date of 2/1/2004. Avast isn't upped yet, so it doesn't know about it.
I downloaded mine from a different source.. and it's not an installer. I searched for pmxgl32.dll and it's not on my PC. It's a stand-alone .exe and i scanned it again with another program.. and it's clean. You prolly got yours from a bad, dirty source :devil: :lol: (j/k with that evil laughter)
Chukundur I flased with your bios, and that's what I get with RT:
Is that all right?!? 3.89V?!? OMGCode:$ffffffffff ATI VGA BIOS information
$ffffffffff ----------------------------------------------------------------
$0a00000000 Title : 113-B34003-101 RV670 GDDR3_8Mx32 256bit 256MB 669e/829m
$0a00000001 Date/time : 10/17/07 10:37
$0a00000002 Core clock : 669.000MHz
$0a00000003 Memory clock : 829.000MHz
$0a00000004 Reference clock : 27.000MHz
$0a00030000 PowerPlay state 0 : 669MHz/829MHz/1.33V/boot
$0a00030001 PowerPlay state 1 : 300MHz/829MHz/1.01V/Overdrive
$0a00030101 Performance level 1 : 300MHz/829MHz/1.01V
$0a00030201 Performance level 2 : 669MHz/829MHz/1.33V
$0a00030002 PowerPlay state 2 : 300MHz/829MHz/1.33V
$0a00030102 Performance level 1 : 300MHz/829MHz/1.33V
$0a00030202 Performance level 2 : 669MHz/829MHz/1.33V
$0a00030003 PowerPlay state 3 : 669MHz/829MHz/3.89V/UVD
$0a00030103 Performance level 1 : 669MHz/829MHz/1.33V
$0a00030203 Performance level 2 : 669MHz/829MHz/1.33V
$0a00000008 Memory type : DDR3
Truckchase! I'm afraid my system was infected with that virus too. I deleted the entry in regedit, and erased the file pmxgl32.dll. Now scanning with all Spyware/AV stuff, but nothing is detected :( I don't know what does that virus/malware harm and I don't know if there are any other files infected...
Could some one please edit my BIOS so that the peak voltage is 1.3v. Or point me to an alternative.Code:$ffffffffff ATI VGA BIOS information
$0a00030000 PowerPlay state 0 : 669MHz/829MHz/1.21V/boot
$0a00030100 Performance level 1 : 669MHz/829MHz/1.21V
$0a00030200 Performance level 2 : 669MHz/829MHz/1.21V
$0a00030201 Performance level 2 : 669MHz/829MHz/1.21V
$0a00030002 PowerPlay state 2 : 300MHz/829MHz/1.21V
$0a00030102 Performance level 1 : 300MHz/829MHz/1.21V
$0a00030202 Performance level 2 : 669MHz/829MHz/1.21V
$0a00030003 PowerPlay state 3 : 669MHz/829MHz/1.21V/UVD
$0a00030103 Performance level 1 : 669MHz/829MHz/1.21V
$0a00030203 Performance level 2 : 669MHz/829MHz/1.21V
Thank you.
What is the size of your guys' hexcmp.exe in the rar?
Mines 472,072 in the rar.
Havent run it yet.....
HEY, wtf is wrong with you man, i scanned the file after i read this with NOD and AVG, it turned up nothing, plus, it's not an installer, it's a direct EXE, check first before accusing blindly.
Could anyone confirm if the file indeed puts in that dll file after being executed?
Just an info ... that dll is a WELL KNOWN mass mailer, it can be had from a LOT of sources, but seriously, check before accusing me of anything, someone please confirm to shut him up :mad:.
