Originally Posted by
Tony
Guys not to throw a spanner in the works but are you keeping mounting pressure constant during these tests?
Intel recommend 17 thru 72LBS of pressure force for core2 and as we know applying 72 over 17 can have a massive impact on how well a block performs.
Im testing the new OCZ block here which is in reliability testing and I have the ability to set 55lbs, 75lbs and 100lbs pressure, I compare with the same mounting hardware each time on each block so I keep apples to apples.
I think you need to ask all the companies what pressure their mounting kits are applying and make sure all are at least within Intels spec's and second you report what applies more etc.
