my 2.8C runs 295, and I'm shooting for 300 with some improved cooling. 4.2 GHz and 300 5:4 is going to be quite fast.
Uhh, pc-memory-upgrade.co.uk are really fast. Friday shipped, today arrived.
Now i need my f***in' Board, CPU and Promkit.
Wanna join your game:D
This is the best i can do for screenie with a pari of Adata's. I can do stable at 267fsb. I believe this is the limit for a 3.2ghz and the adata combo. ihad a 120mm over the mem. and a 80mm over the northbridge. turned the Mach 2 fans to Max. and vcore, vdimm to max. AIrconditioned room with case open.
Ht disabled. mem at 3-4-4-8 w/ 3.2volts
1:1 divider by the way.
They are possible to be found elsewhere that it is not UK? ¶
¶for example in Spain, in Italy or Germany? ¶
¶(I am from Barcelona) ¶
AcuAViVa i know they are possibel to get in Italy i just don't know where!
Whats the problem? 4€ shipping from UK to Spain.Quote:
They have Mushkin PC3500 Level 2 in stock to.
96€ for 256 its more for me... :( i'm seraching but
GEIL 4200 cost 2x256 176€ in spain with shipping
for 2.8C malay? what you bought ?
2.8C without a phase-changer? No A-Data. Your FSB won't be high enough. Search for CL2 ram @ 250-260.Quote:
Finished the A-Data review :)
http://www.oc-zone.com/modules.php?n...teudoing&id=17
I hope you like it...
What does the number after the H mean? Year/week?
what's sandra unbuffered score at around 290mhz 3-4-4-8 with a-data pc4000??
Available in the states for $175 per 512MB: http://www.pcbase.com/category.asp?c...y&vendor=ADATA
I re-read this thread; the first post says A-data is from Japan? i am in Japan but haven't seen any... I would pick them up for u guys if I can find them.....
Their website says they are HQ in Taiwan..
Wouldn't running 300mhz 1:1 with loose timings blow away 5:4 performance with tight timings?
Nope.Quote:
define loose timings though if you can squeeze out 300mhz 1:1 at 3-4-3-8 could be close but hate to see the vdimm you need to run it LOL
